Newbi Help!
Galloway n.j.
Good morning everyone, depending on where you are,I have owned my 1997 80 series since new and decided to add a lift with new tires and wheels also arb bumpers front and rear. I would like to go with 35's but would like to get some opinions on combinations and if a ome 3" lift is the way to go or if there is a better choice. Also would like to know if these changes will need any further alterations in my drive train??? Thanks for any input!!!
Welcome to Mud.
:worms:
Hundreds of threads and thousands of opinions on this subject catalogued here already.
Intended use?
Intended budget?
The search function will yeild lots of results on this subject. 3” lift is sufficient for 35s. But there is no plain OME 3” lift. Several spring heights and rates to chose from.
That thread above is a good comprehensive list to start with.
Also better options? Sure. The slinky kit is hot right now but twice the cost.
If you stay below 3” you should be able to avoid other driveline changes or problems.
Skip the castor bushings and head straight for plates.
If adding a winch then front should be low enough to avoid ujoint grrrrrs or needing a double cardan shaft as a solution. however a 20yr old joint may not be happy running in a new position.
Id pick up the phone and call Kurt and the gang at cruiser outfitters and discuss your use and needs. What other gear you may add etc and they can help you select a lift.
Every change you make typically requires another change. That’s what’s cool, you can just keep changing it and making them better :-) hopefully you have a lot of cash in your wallet or a good credit rating :-)
Read as suggested, but keep in mind 80 lifts are based on equipment and not height. I use heavy's front and rear as I am fully armored and i run 315's with no issues. You can chose different spring combos based on bumpers, winch, gear weight and other things.
