Update:
After finishing my power steering pump rebuild, installing a rebuilt alternator, and removing the old battery-draining DEI alarm, I finally got to drive the truck
without having to disconnect the battery nightly. The cold-start situation got even worse, peaking at around 2,000 RPM. It would drop to maybe 1,800 RPM and stay close to that for probably a good five minutes. I wasn't happy with that, particularly given that it rocked to 2K on the first startup after changing the oil!
I got to work replacing vacuum hoses. I've finished most of the tiny 3.5mm stuff, and all the larger (8mm?) hoses I could reach. That didn't have much effect. I noticed that the PCV hose had electrical tape near the valve. Looking closer, it was cracked, so I replaced both PCV hoses, plus the brake booster hose which looked nasty.
That significantly improved the situation. The idle was more like 1,600 RPM instead of 1,800 - 2,000.
My next step was to remove the IAC/ISC, intending to do the "O-ring trick". I found a lot of gunk in there. I disassembled it, cleaned everything (including the throttle body opening it goes into!), and put it back. I used a bit of Dow Corning high-vacuum silicone grease around the lip where it meets the throttle body. I decided not to resort to the O-ring hack yet.
That didn't fix the peak cold-start RPM, but it
greatly improved the overall cold-start behavior. Now the engine initially shoots to 1,600 - 1,800 peak RPM, but it immediately drops down to around 1,200 RPM. It gradually drops in increments from there, settling at around 900 - 1,000 RPM until it's fully warm.
I will give it a few more days of daily driving before I look into it any further. If the situation doesn't improve, then I'll pull the IAC, test it according to the FSM, test the TPS, check the throttle cable, and then do the O-ring hack because it's vastly cheaper than replacing any of those parts.
Oh, and here's an odd detail that makes me scratch my head: during the cold-start cycle, if I press on the brake, the engine RPM jumps up by around 200 RPM. Remove my foot from the brake and it drops back to whatever it was at. You'd think that means a bad brake booster, right? But the brakes operate flawlessly, and I can apply them quite a few times with the engine off before losing boost. And there is no change in RPM whatsoever from pressing the brake once the engine is warmed up.
