This is kind of a take-off of my other active thread about a timing cover oil leak, which obviously does not have a provocative enough title
I've installed a turbo on a 2H with about 280,000 kilometers on it. Not tons of mileage as far as the 2H goes.
Since the install, (fuel turned up 1 turn, boost to 8 PSI) my formerly non- leaky engine has sprung leaks on both sides of the timing gear casing, and the rear main seal ( the clutch has started slipping and there is oil coming out of the weep hole in the bottom of the bell housing)
In my other thread, a couple of responses indicated that the turbo would cause increased blowby and increased pressure in the crankcase. I am trying to figure out how a vented crankcase, with pistons that run at about 400 PSI can possibly see increased blowby pressure with 8 PSI of turbo boost.
Am I missing something? I have done a lot of searching through oil leak threads and I haven't seen any that correspond to "install Turbo - get major oil leaks.
If any one has any experience with increasing oil leaks after a turbo install, and theories on why, please chime in!
