New Trollhole carb won't hold idle-HELP
Chesnee, SC
II bought this rig, 82 FJ60, off a buddy and he had just installed a Trollhole carb.
It’ll start up and it runs fine above about 1,200 RPM but if you get off the gas pedal and try to let it idle it will stall out every time. I have messed a bit with the adjustment screw on the back of the carb and also the adjustment screw on the passenger side of the carb.
The level in the bowl is right in the center of the sight glass. Complete desmog, only thing on it is vac advance for the dizzy and EGR. It’s been a long time since Ii messed with a carb and this is driving me nuts.
HELP!!!!!
It has new:
Cap & rotor, plugs
Fuel filter
Trollhole carb
Got it to run and idle. Turns out the idle soolenoid power was hooked up to the wrong side oof the connector. Sometimes it is the obvious staring us in the face.
