New seats
ATL
Finally got around to putting some seats in the 80. They are out of a '05 Lexus 470, so they had a memory module. Of course, that was missing. Still need a seat switch out of a 100 series, but my switch from the old seats make it move.
Would I recommend? No way!!
They are comfortable, and there is more leg room now, but almost too tall for a 6' dude.
I would recommend another option.
I'm surprised I haven't seen this before, but if they're too tall, that might be why. I'm 5'8" so it might be worth considering :hmm:
View attachment 1257270 Finally got around to putting some seats in the 80. They are out of a '05 Lexus 470, so they had a memory module. Of course, that was missing. Still need a seat switch out of a 100 series, but my switch from the old seats make it move.
I would recommend another option. View attachment 1257272
So you sit up higher on these than you did on the originals? Less head room? I like the seats in the GX470 and wondered if they would be a good fit, were these from an LX or a GX?
I assume an LX, but not really sure. They are higher at the lowest adjustment then the factory seats. Only way to make shorter is cut the floor pan. All I did was cut out the rib to the trans hump, then "massaged" the hump with a hammer until the doors would close. Then I welded a piece of 1/2" x2" channel where the rib was, and through bolted brackets that were welded to the bottom rail of the track.
I also used the original brackets from the rear of the original seats. Just trimmed them to fit to the track.
