new scan gauge mounting solution
I take it there is no way to do this on a '94 and I'll have to stick to custom gauges for some of these readings?
Right, the scan gauage only reads OBDII data, which did not arrive until sometime in model year 1995, for the Land Cruiser.
where is the alternate ODBII port?
Also can you use both ports at the same time?
Ie either two scangauge units (someone has daisy chained them to get 8 display options at once)
But I would like the scangauge II plus a bluetooth ODBII scanner gauge to run onto a pc or android tablet.
Any thoughts?
Regards,
jas
Not an alternate port, an alternate mounting position for the connector port. You can rotate it 90 deg so the port is facing downwards, then you can leave the SCII connected without having to leave the fuse cover off.
