Finally bought a cruiser, been looking around and found myself a 1997 lx 450 with 166k miles. Would like to do bunch of maintenance / fix leaks and have a couple of questions.
1. Leak, front driver side. Have not fully checked but thinking it would be the oil pump seal? If i were to do the oil pump seal, I will also replace distributor o ring and front main seal as well? What else should be done or look for while the pulley is out? Any good diy link?
2. I hear a hiss/noise near the distributor. Does the distributor make any noise? What parts need replacing to service it? Cap and rotor only?
3. My car also takes about 2 seconds of cranking before actually starting. Crank is strong just does not fire up from the get go
4. Where do you guys buy/order parts, online or local toyota? I’d also like to find out about the part no. Of the seals.
Thats it for now but I will for sure have more questions. Thanks!
