New OEM Spec Brake Booster for '71 to '75 FJ40 / FJ45 / FJ55 / BJ40
Palo Alto, CA
You read that right! This is a brand new brake booster for 7/'70 to '75 Land Cruiser FJ40, FJ45, FJ55, and BJ40 with drum brakes, built to Aisin spec 44610-60030. Exclusively offered by City Racer LLC.
There is no longer a need to search junk yards for a 20+ year old substitute booster that doesn't really fit your vehicle. This brake booster is plug-and-play, and can be installed in as little as 30 minutes without needing to disconnect any brake line or bleed the brakes.
Our booster is designed to be installed with a spacer so that you have ample clearance to the clutch master cylinder. The spacer is included.
Price: $225
Shipping: $25
Price includes a brand new check valve!
No core charge
1 year warranty
Note: This brake booster is for Land Cruisers that have retained the original drum brakes on all 4 wheels. If you have converted your vehicle to disc brakes (either in front or both front and rear), you should not use this booster.
