New here, finding my bearings :)
Georgia
Hello, I just bought this LC and received a large box o parts for the front axle rebuild. PO was very kind and told me he knew some things fell out, etc, but at least I could use the parts.
So, I've inventoried them, and come away somewhat confused. I have the original bill of sale for the parts, and the list here: Front axle rebuild - OEM P/Ns here
I have 6x of the 90368-45087-77 bearings. PO only ordered 4, but even that I am confused about, as from what I can tell, only two are called for. Making matters worse, these were mixed in with boxes that indicate they are 90368-49084-77 bearings.
The bearings look identical:
Any ideas why this would have happened? I've gone and ordered the other bearing, 2x of the 90368-49084. I'll probably sell the 4 unused bearings here, but want to make sure I don't need them,
Cheers,
John
They are for the rear. There are (8) of the exact same sized wheel bearing on your truck. (Assuming your 80 is 1994-1997.)
The Toyota part number is what you ordered, but the actual bearing part number is whatever the bearing manufacturer makes it. Many of the bearing mfr's use similar part #s in order to be the same.
To make sure they are all the same, you can carry what you have into your local O'Reilly Auto Parts and ask them to cross-reference the bearings to each other. You can even cross a Toyota P/N to what you have in your hand.
Good to know, the numbers on the bearings are identical, and two are missing. In the various instructions on the site, I see mention of 1x of these per side, but you're saying 8 of the 90368-45087-77. Where do those go (not explicitly beyind FR, FL, RR, RL)
LF inner, LF outer
RF inner, RF outer
LR inner, LR outer
RR inner, RR outer
All wheel bearings. There are (2) wheel bearings per wheel. Along with seals, grease and torque-related values.
Y'all need to try the search funstion on here to look up wheel bearing or front axle rebuild.
Oh I've read, and read and read. However, the inner bearing has a different part number than the outer bearing. I have 6x of the same exact outer bearing. I don't think (correct me if I am wrong) that there are two outer bearings per wheel, only an inner and an outer.
First, let's start if you have a FF or semi-float rear?
All mine are FF. Inner and outers are all the same for all 4 wheels. Rockauto has them, ebay has them, toyota has them and vendors here on mud have them. Easy button answer is to call cruiser outfitters and they'll help you figure it out. They're a little more money but after my last experience with them I'm a convert and my first sticker in a window will be a cruiser outfitters sticker.
He's got a 1994, so FF for this one.
Let's clarify a bit, because I made the same mistake.
All INNERS are the same.
All OUTERS are the same.
The INNERS and OUTERS are different from each other.
Correct on the clarification.
Right, so the point of confusion is why anyone would every have 6 outer bearings...
Anyway, thanks!
Maybe original intent was to rebuild front and rear diffs... that would take 4.... then the other two were for spares.... 1 for the emergency kit left in the truck and 1 for the garage shelf.....
Or along the same line, went to rebuild, checked the current bearings and called them still in good operation and replaced the bad ones.
Anyway, thanks!
One thing I have learned over the years is not to waste time/effort/energy speculating on the reasons POs did what they did. This is a tree that bears no fruit.
Either way it's nice to have all the free bearings thrown in with purchase. Don't store them unwrapped. Put some grease and wrap in plastic wrap.
