New Header & complete Exhaust Question
Fountain hills, AZ
Since my Exhaust manifold is cracked I need to replace it, & since the PO had some crappy muffler shop build and Exhaust that sits under the frame rail of the truck that also needs to be replaced... So I was looking at...
MAF Tuned Header Bolt-On Exhaust System FJ40 for the Exhaust
& This
MAF Tuned Ceramic Coated Headers F and 2F Engines for the header
Now I know I need an Exhaust manifold gasket, but am I missing anything else... I want to replace everything from the exhaust ports on the head to the tip of the tail pipe.... Is there anything any of you see that I am missing...??
Thanks in advance
Jeremy...
oh yeah it's a 1977 FJ40 cat exempt truck... If there is a different complete system any of you would recommend instead please link it for me to review..
I have the Man - A - Fre Tuned Ceramic Coated Headers and really like them. My 40 is a '78 and I also purchased the collector pipe as they did not have a complete system that worked. I installed the headers and the collector pipe and drove to the shop where they cut off all but the collector part of the pipe and then they route the new exhaust line out the back clearing my aux tank. Here are a couple photos of part of the exhaust line.
I have the same header and love it. It comes with the gasket though. I had my local shop build the rest of the exhaust like you have pictured, that way I could use a flowmaster muffler and get a deeper tone. They charged me $250, so if I payed shipping it would have cost me more to use MAF's. My rig sounds nice, kinda like a SB 350. Be careful to not get any fluid (brake,power steering) on the headers, as I did or it will rust in spots prematurely. They look great when installed.
Here is mine.
Where did you get that skid plate???
Looks kinda like the Downey Off Road skid plate.
I have the same header and exhaust combo. Put it on when I had everyting torn apart when I switched my carb mack to Aisan and fixed a crack in my intake manifold. Comes with a gasket, the only thing extra I did was replace the manifold studs, bolts, nuts and washers. Yota dealership had them in stock. Install was uber-easy the only thing is after, you have to pull the exaust pipe off to remove the B/H cover.
I like it:meh:
