I think my new head gasket may be leaking.
I purchased my 97 FZJ80 about 4 months ago. The PO installed a new head gasket about 6 months (I think) before that. About a month ago I noticed a couple drops of coolant under the bell housing, but didn't see any coolant above. I wiped it off and continued to drive it. Maybe a week or two later I noticed a small bit of coolant on the ground under the truck, and this time I could see a wet area on the block behind the starter and a couple drops of coolant dangling from one of the oil cooler lines and on the underside of the PHH. I noticed the PHH clamp and all of the clamps on the other heater hoses were a little bit loose, so I snugged them all up. I continued to drive it and saw no more drips or wet spots under the truck or on the side of the block. I thought the problem was solved. Then one morning after a cold night, I saw the drops on the cooler line and side of the block again, but not under the PHH. I also noticed that it was wet on the top of the block, next to the knock sensor and just under the PHH. I didn't see anything leaking from the PHH.
I dried everything up and drove it a few miles then came back to the house and checked it again. Everything was dry and stayed dry until yesterday morning, after another cold night, it was wet behind the starter again.
I think the head gasket is leaking by the #6 cylinder and coolant is flowing over the side of the block. The head gasket has blown? Maybe the head bolts have loosened? I think when it gets cold enough, the head and/or block contracts just enough to allow coolant to seep out around the head gasket.
I'm afraid I'm going to have to replace the head gasket again. Any other ideas about what is going on here and what I need to do to fix it?
In the second photo, you can see what looks like staining on the block, under the PHH. It is almost dry in the photo, but it appeared wet before.
