New guy needs some help
Spokane wa
Hey gents, im a brand new member of the forum but a long time reader. Finally have the funds and time to rebuild my 68 fj40. It has a conglomerate of different parts, including a saginaw steering kit, 76 front end, semi built 350 chevy with turbo 350 with factory transfer case. As of right now I'm in the decision stage for front and rear lockers. The front end is no issue with availability. But the rear being a 68... means that at this point I can't find a company that makes one. I know they changed axle spline count in 69+ and that is what every offers lockers for. My questionson are,
1. Are there any lockers that will work with my current rear end? I have combed and combed online with no such luck.
2. What all would have to be done to the rear diff if i were to buy 69 axle shafts? What are the other parts I would need to change in order to do this(or is it something that is even worth doing)
3. Is there a complete axle swap that is common in the rear that keeps the same width, pumpkin location, and offers disc brakes? If this is an option i would seriously consider it given i will be doing disc brakes in the rear anyway.
Thanks a ton for any and all replies, i did search for answers pertaining to this stuff but was unable to locate anything that was as specified as what im after. If i missed it, feel free to new guy shame me!.
Would I be crazy to think i would he able to use a 69+ rear locker, (lunch box or arb) which replace the spider gears and then run the 69 axles that correspond with the locker? Everything else on the axle is the same, the axle bearing and outer seal, so in theory this should work, has anyone ever tried this?
That will work. There are also 10 spline Lockrites available in classifieds. That’s where I got my last one.
I recommend you not buy ANYTHING until you pull the rear diff cover and positively identify what you have. You may have a 30 spline and not know it.
Once you’ve IDed things, you can give me a call at the shop and I can set you up with bearings, seals and gaskets. Maybe even a 10 spline locker if it turns out you need one.;)
@65swb45 what's the shop number boss!? That's a good point on pulling the cover and I wasn't going to purchase anything until I tore it down anyway, but I appreciate the heads up!
Google search Mark's Offroad and you will discover shop number.
You can also click on his handle. His contact info will appear.
All info is linked in my sig line, which is apparently not readily viewable from Android “smart” phones. Which is why I added it to my avatar as well. ;)
Thanks gents! Yeah I clicked on your name, but, I have android :( so that is probably why I saw no pertinent info
Click on his name, then his profile. The number came up for me.
