I don't know. Maybe. I'd go to the local industrial supply store and see if you can find some studs to put in there.
Pls share. Thanks!I have the specs on a receipt for mail order rear glass if ya need also. Ill try and find the receipt. Was pretty cheap.
I see, so the holes don’t come drilled all the way through from factory? Mine were all drilled through like pic below, I think even the two that had studs (I broke one and replaced it). I had assumed they were like knuckle housing holes, all drilled through.It should not leak through the threads (unless someone drilled the holes through) but if the bolts are too long you can’t torque the cover down properly.
Pls share. Thanks!
forum.ih8mud.com
It’s been a while since I performed any diff work. I don’t remember them being drilled through.
I checked on our ‘77 today, and the holes are definitely through, I can feel the studs from inside the housing. And I think the studs are bigger compared to the ‘65 that I’m missing.Studs should go all the way through.? But I'm getting old. Lol
Run some toyota black fipg if your concerned about leaks. Tighten the studs up with double nuts.
Mike
