New axle shaft too short. Remote location.
It would help if you post year and model!
Now if you have a 70 series then a longer C.V.(birfield) is what you want.
The newer 80 series C.V. will fit.
If you have part-time or electric hubs you can convert that side to functional by removing the parts and simply add a drive flange of the appropriate thickness.
Note my 75series...one part-time hub on drivers side, full-time on passenger side.
The 79 series will fit, But you need to file or machine the top outer splines to fit the drive flange.
I did post the year and model number near the top of the thread.
2016 HZJ79R-TJMRS
So...
The wrong axles were supplied by the parts supplier. I was going to use the old shaft like @Broski said. Once I started cleaning it up and sanding it to get the burs out I noticed it was bent. I was able to find the short end of the shaft locally (we are in a remote town in Papua New Guinea which is a remote island country) and thank the Lord got it installed and put back together.
Thanks for all the input!
