Need tire help and pics
Golden Colorado
I have done numerous searches and cant find what Im looking for
1) Will a 31x10.5x15 rub on a stock FJ 40?
2) Does anyone have a picture of a stock 40 with
31x10.5x15 and also
30x9.5x15
Is there a metric size equal to a 31x9.5x15 or 32x9.5x15
Thank you much
I have read all about 33x9.5x15 and thats what I have now but I want a bit smaller and skinnier tire but not sure I want to drop all the way to a 30????
Thanks a ton!!!!
Here ya go.
here's mine on 31x10.5's
depends on how saggy the rear springs are, I had to put a bit longer shackles in, but if your rig sits level, you'd be ok. also flares would help in the back, but no big deal, might depend on rim backspacing too.
31 x 10.5 x 15
I have them on mine.
The only place it rubs is if I turn hard hard right the tire rubs on the steering arm knuckle on the front. circled. I have a bone stock suspension.
31x10.50
I ran 31x10.50 for a number of years and the only interference issues I found was when I was 4 wheeling and had one side of my rear axle drop free. The compression on the other side would touch the sheet metal and caused a mild distortion that was there to stay. My factory springs were tired and not to spec. When I put an OME 2.5" lift in, I got more than 2.5" of lift. Just an indication of how much arc the factory springs had lost. I rock crawl with 33x10.5 and there is no rubbing or distortion on the rear panels.
I ran 31"x10.5 on my bagged out original suspension and never rubbed a tire front or back even in the worst situations. Just insure that your rim has the proper back spacing to keep the wheels tucked inside the rear fenders when the suspension is fully compressed and adjust your steering stops in the front to eliminate any clearance issues when turning. But if you say that you are down grading from 33" you shouldn't encounter any of these issues unless that is why you want to down size.
My mistake it looks like your reference to the 33' was just under your research. I had to change my rims when I had installed the 31's but it was only so I could run 10.5'' wide tires. The factory rims were only 6" wide so I upped to 8" wide to run the 31"x10.5" rubber. But I don't think that I ordered any particular backspacing on my rims.
Steering stops
How do you adjust the stops?
The closest metric eqeavilant for the 31"X9.5" is a 225/85R16. This is a 16" wheel however. The width is 9.5",height is 31.70. The plus is that it's available in a host of designs and manufactorers. However, only available in a 16" wheel. 15" wheel is limited to the BFGoodrich AT/MT 30"X9.5" or the 33"X9.5"AT. Swamper makes the 9.50" X 31" and 32" but i hear there loud,extremely difficult to balance, and they wear quick.
These are Goodyear MT/Rs in 30x9.5x15 on stock sized lift.
There are bolt with locknut adjusters on both knuckles. Seek and ye shall find.
Unless they are MIA, like they were on my FJ45....:D
thanks
I'll look at her this weekend. It's in my garage undergoing a tub bedliner job at the moment.
