Hello fellow muder's I am at a cross roads and thought I would get the opinion of the mud to help me make a decision.I have a 96 80 series not currently a DD with 109K on the OD the head gasket has not been replaced. I am going to be switching to a diesel (because it's mine and I want too).
I live in Mesa AZ so it will need to pass the Kalifornia type emissions test I contacted Strictly Diesel here in Phoenix and was informed AZ requires engine swaps to be the same year engine or newer and pass emissions for that model year so that's what I'm going with.
I have narrowed it down to two-ish options a GM 6.5L or a Toyota 1HD-FT (first choice) / 1HD-FTE I have listed the Pros and Cons I have come up with below, please feel free to and your 2 cents. I ruled out the cummins BT4 for noise levels and the Toyota 1HDT because last year of manufacture was 1995 unless I am mistaken.
GM 6.5 Pros
I can get a newly re-manufactured one for between 5 and 6k with a 3 year 36k mile warranty
Only need a 3in lift to install
Would also have a beefy 700R4 with 0 miles behind it and a new torque converter
Parts are easy to find at local parts stores
Lots of diesel mechanics have experience with them
Not super loud
Don't shake like a dog s##ten a peach seed
Weights about 750
Intercooler available (not sure if it will fit in the yoda)
Can buy a piece at a time
GM 6.5 Cons
Not known as the most dependable diesel ever
EXTREMELY sensitive to overheating
Main Bearing Web Cracks,Crank Failures,Cylinder Heads Cracking
Would cost more to install than a Toyota diesel
Needs a Different transmission and torque converter
Needs an adapter for the T-case
Toyota 1HD-FT 1HD-FTE Pros
Its a Toyota
Easier to install than the 6.5
Not super loud
Intercooler available that fits
Toyota 1DF-FT Cons
Don't grow on trees
Parts don't grow on trees either
Not a lot of mechanics have ever worked on one
Price
Will most likely have more than 100k on it
The 1DF-FTE would cost more to install
GM 6.5 Pros
Not super loud
Weights about 750
GM 6.5 Cons
Its a Toyota
Not super loud
Toyota 1DF-FT Cons
Don't grow on trees
Price
