Need some help
here are some close-ups of my box. the top # is 7650-61010. hope this helps. chris
According to the EPC,
17650-61010 is 7501-7602 Fed.
17650-61020 is 7501-7608 Cali
17650-61040 is 7608-7709 cali
Chris's truck has thermonuclear manifold, cali carb, and the original California emissions compliance sticker underhood. But some things were not hooked up right and it has a '75 Fed control box.
Maybe the truck was in the same situation as Dan, throwing random parts at it to get past cali smog nazis sometime in the past. Fun stuff.
Texican
What is that black box on top of the thermostat housing? Is it just a cover for the BSV? I have never seen one before. Don't go looking it up, I was just curious.
it's a cover, made from the same stuff as the distributor snap on cover, kind of thick rubber, I imagine they got lost or damaged on most trucks....first time I have ever seen one.
Thanks Jim!
(sorry about pissing your off :o)
I bolted the 6010 on it since it looks like I have the Federal system. If followed the plumbing diagrams and connected the VSV.
I just have a couple of questions.
#1
Does it matter if I connect the VSV line to the upright 3 nipple boss on the intake manifold approximeatly even with the #3 cylinder? Or does it have to be connected the the big nipple coming out of the intake manifold that connects to the PCV valve? My PCV valve to intake manifold connector does not have the "small" nippe on it, only the one for the PCV valve. Post #26 has a great picture of what I don't have.
I will think of the other questions in a little bit.
I think the charcoal canisters go on the passenger side of the engine compartment.
#1 Are these the corrrect ones for a FJ40?
#2 Physically where do they bolt? The one wth the frame around it has a hump like it would bolt to the frame. They other one looks like the same jsut without the frame.
#3 It has wriing.
# 3
Why would someone shove a ball bearing up in the vacuum tubing? This was 1" or so up in the tubing.
Howdy! That's one of the easiest ways to block a vacuum like that needs to LOOK like it works. Called De-smog bearings. Usually right next to Muffler Bearings on the MicroFich, but I don't have a current part number for you. Rumor has it that OEM is unobtainium, but I think I have several used ones, $20 each, plus postage. John
The one on the right is pretty close. It bolts to a bracket that bolts to the fender under the heater fan on the passenger's side. The one you have is 9-77 or later. You can just bypass the the output valve (#31). Don't chuck it though. It's $60 used from $OR. Details of this bypass are left to the reader.
I haven't seen an EGR valve with an electrical connector on it. I'm sure the smog tech hasn't either. :)
BTW: I've got some OEM desmog bearings you can have for $10 for the whole set. Paypal is fine. I think that inkpot dude is trying to rip you off.
#3 It has wriing.
The correct charcoal canister for your vintage is about 2" shorter and slightly smaller dia than the ones pictured. Will have two ports on the top, and one on the bottom.
As for the EGR, I dont recall a temp sensor(the electrical connection) on the egr valve in my 2/'76???
Do you have a white or black emissions sticker under the hood? I seem to recall white with black type was federal, and black with white type was cali.
White Decal Black writing on my 1976.
Black decal with White writing on my 1977.
I connected all the hoses and double checked every bolt, nut and electrical connection. I as able to get creative and install my power steering pump in umongst all the smog stuff.
The throttle cable conversion was a little tricky but I was able to install it wit the wife help.
Fired it up last night and took it for a test drive. I purs like a kitten.
I did notice when it is warmed up the idle is pretty fast.
I'm gonna road test it this morning on "The paved roads".
Once I realized that I had a federal rig instead of a California rig and started looking at the correct picture in all the manuals (thanks again Jim) it was not that hard.
Thanks for all of you help!:beer:
