I have a 77 that is all hooked up and passes smog everytime, i am in fresno. you can come by and look if you want, not sure if pics will help ya...
GL ...
GL ...
GL ...![]()
Should I be using the # 17650- 61010 VSV or the # 17650-61040 VSV?
Dan, there's a good drawing of vac routing and a schematic in the Haynes book.
See fig 3.100 & 3.101.
I thought initially you only needed to see the positioning of the components.
I found some references in my Haynes manual #92055(313) that covers the 1968-1982 FJ series.
The diagram 13.3 on page 271 shows to be for a 1977. The 1977's uses a lot more vacuum lines as well as the BVSV valves on the thermostat housing.
The next set of pictures are for the 1981 and 1982 with the air injection system as well as the 1979 and 1980 models with the ASV system.
Everything seems to skip over the 1976 CA, Fed equiped rigs.
Warning: patience just ran out.
You have the Haynes book.
Fig 13.3 is a 1978 Federal 2F.
Which part of Fig. 3.100 and fig. 3.101(labeled "emission control 1976 California model") is not clear?![]()
D'animal:I am not seeing a cali exhaust manifold on your truck? Looks like the 1/'75-8/'76 federal spec manifold to me? I would install the federal spec emissions stuff, since its going to be easier...plus the emissions manual clearly lays out what you need. I seriously doubt any smog tech is going to be able to tell the difference.
did you find the egr "J" tube and correct cooler?
LOL!
Thanks for your help Jim.
I found 3.100 on Page 87.I kept looking under the suppliment section in the Haynes.
get a lot of firepower, eliminate anyone associated with the emissions program, and leave the 4 1/4 miles of vacuum hose off. you'll be happier without having to figure it out, your engine will be happier without all that crap on it and the rest of your state will be happier when they don't have to deal with the emissions control monkeys.
seriously, good luck. i think i still have a 78 emissions manual from the nuclearlemon. let me know if you need to borrow it and i'll send it out.
