Need some help with cable. Where does this go?
Mikesta
Never decruiserfied
Missouri
Website
www.showmerents.com
I just swapped engines. I have this cable left over, looks like a ground, but I'm not sure. Does this ground the engine to the frame?
Thanks
If one end is bolted to the frame now than yes it is a ground. Bolt it anywhere on the motor it will reach. Make sure you have a clean mounting surface. If it is bolted to the motor. Bolt it to the frame. same same clean ground is a happy ground.
Hi MIke,
I really can't tell by your photos, but you should have a cable from the battery negative terminal to the frame and a cable from the frame to a starter mounting bolt. The cable from the battery (-) terminal bolts to the outboard side of the frame just aft of the PS shock. The cable from the starter mounting bolt connects to the top of the frame below the charcoal cannister.
Hope that helps,
Todd.
Yes.
What is the effect if you don't ground the engine?
Not having a good ground can cause electrical anomalies and create voltage spikes that can damage electrical components.
Resistance to current flow causes heat, which can burn up the insulation on the wires, and cause all sorts of drama.
I had a truck in the shop a year or so back that was grounding through the aftermarket choke cable. Was pretty funny to watch the choke cable start to glow after about five seconds of cranking the engine.
:beer:
Is it me or is this the positive battery cable? The red would go into a fusable like that is white and into the wire harness.
Thanks Todd, I will hook it up tomorrow.
Look beyond the red cable.
:beer:
I am still missing it..............Maybe the tears from OME pain is clouding my vision.....:D
Both of my + and - cables are black.
If the engine isn't grounded its real hard to start. Since I've had this truck its been acting like this. After grounding it last night it turned over like it should but didn't start. After flipping the dist 180 and tweaking it, John and I were able to get it going. Electrical junk intimidates me.
When I removed/reinstalled my 2F I forgot to hook up that ground and when I tried to start it the accelerator linkage started to glow red. I couldn't believe it.
