Need Possible Head Gasket Advice
Oahu, HI
So here is the back story. A few weeks ago while coming home from the store I noticed the temp gauge starting to slowly creep up. Luckily I was less then 2 mins from home so was able to get it in the garage before it overheated. Checked the coolant in the radiator reservoir thing and it was empty! Then waited for it to cool down and checked the radiator....didn't see any coolant in there. Filled both back up with coolant and monitored the temp gauge and coolant levels over the next few days. Temps were ok, and any fluid loss was not noticeable in radiator or reservoir over the next couple days. Then.......a couple days later the engine started really hesitating and sputtering upon acceleration. Idle was fine, but happened only on acceleration. And just about that time the Check Engine Light came on!
So decided to take to a recommended mechanic close by to take a look. He said the check engine error was coming up on #6. I didn't quite know what that meant, but I shook my head yes and said mmmm like I knew what he was saying. He did a compression test on the radiator and said the compression was good. He thought it might be a head gasket issue and recommended I try this stuff called "blue devil" head sealer first. I was hesitant for him to put anything in there, so excused myself and got on MUD real quick. A search on this Blue Devil stuff came up with mixed reviews with the general consensus that it was a band aid fix for a larger problem but some people had success with it. Since I knew I wasn't going to have him do the actual head gasket repair, I agreed to let him put it in so I could consider my options.....with taking it to the Toyota dealership being my initial thought for any major head gasket job. They are super expensive, but I know they will use all OEM parts and stand behind any work they will do.
After leaving the local mechanic the engine and acceleration ran smooth, temp gauge was normal and the truck ran great. Plus, the mechanic fixed my AC so I was loving the ice cold air for the first time in my LC!! Because it started up and ran so good (maybe the best since I got it 3 months ago) and the new AC was sooo nice, I haven't taken it in to Toyota for their assessment. But in doing research on this forum for the last couple days....I am beginning to have head gasket paranoia! Reading about catastrophic head gasket failure has got me a bit rattled. Do the symptoms I described above seem to fall in line with classic head gasket issues? Could it be something else besides the head gasket? The PO had no maintenance records and I couldn't find any accept for a few oil changes back in '96 on the Toyota site using the VIN. So I don't know if it has ever been replaced. Any thoughts or advice on this would be much appreciated. Thanks,
Jen
What year is your truck, if 93 or 94 I wouldn't be surprised at all if its the HG. It seems like they were the most prominent. My advice is run it around for a week or two and see if it overheats again. You should also do an oil change soon to get out any coolant that has contaminated the engine. I'm not well read on that particular sealer but there are some out there that do work. I know my dads shop will use it occasionally.
It sounds like you're probably fine. But that's about how my head gasket went. Temps were hard to control, acceleration with white smoke in the rear, missing at idle, etc. I wouldn't worry about it going though. I doubt when and if it goes it'll be catastrophic.
If you can wrench, that would be the best bet. It took me 13 days and about $1300 in parts. If you use a dealer, I'd be surprised if you got out of there in less than $5k.
It could definitely be something else too.
Its a '95. I am coming up on 2 weeks with it driving like a champ. Coolant loss has been minimal in the reservoir and I checked the oil cap and didn't see any of this "chocolate milkshake" that you guys refer to. Oil looks like honey on the dip stick and do not see any oil in the coolant.
Just drive it & monitor temp. Check coolant fluid every couple days. There's an overabundance of 'the sky is falling' head gasket scares.
The head gasket seals three things: very high pressure combustion and compression gases, oil passageways, and coolant passages. The gasket can fail from any point of these three to any of the others. You can have oil-coolant mixing, oil-compression mixing, water-compression mixing, or all three mixing up. Any combination is possible. What you describe sounds like compression gasses into coolant. There is an auto parts store test you can use to detect this one.
The misfire on #6 and missing coolant is a very strong sign of a HG problem. Since you put the sealant in and it isn't losing coolant, keep driving it and keep an eye on the coolant level, but start saving up for a headgasket job. The sealants like your mechanic put in can buy you a lot of miles when you catch it really early. As you already know OEM at the dealer is going to be pricey. Personally I'd add a third party temperature gauge and learn what the readings mean, and what the values should be. I'll bet you'll find it is running on the warm side all the time, and it's obscured by the friendly temp gauge on the dash.
Under normal conditions, no coolant is lost at all, it's supposed to be a completely sealed system. Another possibility is that you have a tiny leak in a small hose that is evaporating against something hot, so you slowly lose coolant, but the misfire #6 condition would not be explained by that.
In the meantime, have all the hoses checked carefully, the small hidden ones are the real menace, and there's a good number of them. If there are any coolant hoses on it that are original, they should be replaced as a matter of preventative maintenance, they have a finite lifetime of about 15 years. They can and do last longer, but will certainly fail with continued use, it's just a matter of time.
Thanks for input guys. After monitoring the temps and coolant levels the last few days, I noticed the coolant reservoir was filling up well past the "full" mark after driving....almost to the top. So I decided to take in to Toyota dealership to finally assess. When I pulled into the dealer service bay, I turned off the engine, get out of my 80, and I'm talking with the service manager. All of the sudden it just starts raining coolant from the passenger side of the front end! We popped the hood and it was spewing coolant from the reservoir overflow tube. Seemed like perfect timing to pull in to the service bay and it vomits coolant everywhere while I am explaining the problem! I am assuming it was excessive pressure from the engine forcing the coolant out??? Any other things other then a head gasket issue that would cause this? Thanks again for all the input, I appreciate and enjoy learning about how it all works.
Did you ever open the radiator cap and make sure there was enough coolant in that part as well as the overflow reservoir?
Unfortunately, this DOES sound like head gasket.
Have them do the exhaust gasses test on the radiator.
Can also look at each of the spark plugs to see if any (probably #6) is steam cleaned and looks "new".
The only other possibility that would cause this to blow out the overflow is a bad radiator cap. Typically, the temp spikes immediately after shutting down and will build pressure in the radiator. It COULD be as simple as a new radiator cap needed, but unlikely. Purchase only a Toyota rad. cap.
Good Luck! Sorry to hear the bad news!
This is actually quite a good description of HG failures. I'm surprised I hadn't read this in anybody else's post and gives me a better idea how to describe it to others.
I agree! I found it very helpful for understanding the process. Thanks again @sbman .
Idk if its a hg or not, hard to tell over the intertubes... But... in the future... I'd run as fast as possible from all those head gasket sealants! They might buy you some time, but usually end up making things worse down the road, like clogging passageways, and practically gluing the head to the block, making hg replacement that much more difficult.
I cant even tell ya how many times someone had poured that stuff into their vehicles, then brought it to the shop I worked at a few weeks later for the same issue, and found that the repair bill was gonna be almost double do the use of those sealants, if the repair could be done at all.
So what ended up happening at the dealer? Hopefully this isn't like the thread from @80drifter that we never hear the resolution.
It's been at the Toyota dealer since last Friday. I checked up on it yesterday and the service manager said they have been backed up, but they did get a chance to look at it and said they were having a hard time finding a leak because of the blue devil HG sealer that was put in. Don't know if that was really the case as they seemed really busy, but they said they will let me know when they have a conclusive diagnosis. So....I am impatiently waiting to hear back from them. I have a feeling they might have it for weeks, since they will still have to order all the parts from the mainland. Fortunately it's not my DD. I will update progress as it comes along. Thanks again for all the comments and advice.
