Need Part Number: JDM Electric Winch Level
Philippines
I have the JDM Electric Winch - A1000. It came with the controller only. I'm looking for this particular part in red circle in the pic below. I think this is the lever to enable free-spooling.
Hope you can assist in providing the part number for that black lever.
Try posting in the Diesel/JDM forum. Lots of 81s in there.
Can you point it out in this picture? I only just got my EPC so I have not figured out how to post the pages but depending on the year of the which it looks like it is either
38221-60180 1/90 - 10/90 or 38221-60181 10/90 - 9/99 refered to as "LEVER, CLUTCH HUB SHIFT"
It is not shown on your EPC diagram. But I attached another picture I got somewhere in mud to illustrate where that lever goes - see attached in red square.
38221-60180 1/90 - 10/90 or 38221-60181 10/90 - 9/99 refered to as "LEVER, CLUTCH HUB SHIFT"​
I have that lever on my winch. you could easily make it yourself, all you need to know is the thread pattern - I will find it for you. Then just use a bolt with the same thread and attach a handle.
If you want OEM handle - good luck.
contact either Japan4X4 or Mot on the forum here... they will be able to help you...
lshobie - thanks for the advise. I might just do that trick. If you can send the thread pattern, that's even better. If not, I'll just do a trial and error - got lots of nuts/bolts in the garage. I'll just have my friend weld it to nice steel handle and then paint in black.
Cruiser804 - thanks for the Part Number - I'll check with my local Toyota dealer. If available and does not cost more than a case of beer, then I'll just order it. If more, then i'll just by my friend a case of beer to make the improvise handle.
Thanks again for the info provided by this forum.
Yeah, I see that picture. It's one of those 2 part numbers.
Or landcrusher80. If I remember correctly they cost around US$30. PM me and I will get you one right away.
Landcrusher80 was wondering if you were able to still get this part? Part number is 38221-60181. Thank you in advance. Tried to PM you but inbox is full.
