Need More POWER...HELP ME PLEASE!!
Damascus,Oregon
Website
www.myspace.com
Hello I am new to this forum and I need your help. Im looking to free up some power for my FZJ80. Later on down the line I want to swap a EFI 302 in her but my stock motor still runs great. I just would like to get a little more power. So my question is what mods have you other guys done to get more power/ which ones have worked the best, is pretty much what I am asking. I was going to do a throttle body spacer and some electric fans on the radiator for now. But maybe some exhaust or intake should be done first? Suggestions PLEASE:) thanks
-Peace Will :beer:
You could rebore and mill the head, but thats a major engine mod
Supercharger or turbo is the only way to make a significant difference
Progressive Nitrous and timed Propane injection... though I haven't done it.
Unless you want to spring for a supercharger or a turbocharger, both of which are nearly impossible to come by, I would forget it. Seriously. You can spend a ton of $$ on bolt on goodies and make no real contribution to performance. In all likelyhood, you will make your truck worse.
If you want more power, get a Tahoe or a 100 series.
If thats your 96 in your sig with 33" tires and stock gears, then you need to change your gears to 4:88 from stock 4:10's if you haven't already.
For about $1200, you will see major gains in performance.
Comin' from a 3FE guy, too... :grinpimp:
I was thinking about putting 4.88's in my truck. How does your truck do with city and highway driving? The only reason I was thinking about the exhaust was just to let her flow a little bit better you know....also it will give her some more attitude:D
You can make mild gains with an aftermarket exhaust, but the manifolds on the 1fz flow very well. The rest of the exhaust is also pretty good--you won't see a whole lot more with a different exhaust, but there will be some gains.
Gears is definitely the way to go.......(says the guy with stock gears....)
Ok thanks...Yeah for exhaust I was going to run maybe a high-flow cat and a dynomax muff. keep it all like 2 1/4" maybe 2 1/2" at most. I dont want to do alot of bolt-ons just a couple, because other wise I will just swap a EFI 302 in her.
engine swap power upgrades for toyotas are worthless unless u drive a supra
What about more aerodynamic windshield wipers? No?
-Peace Will :beer:
Cheapest way to get some extra power is a K&N air filter, (some owners do not like them, but I have used them for 20 years with no problems),
then change all your fluids to synthetics; less drag on the gears,
moving engine parts, tranny,etc,etc.
If you have $20,000+, you could have someone stuff a GM Vortec
into your cruiser; easier to just buy a GM.
If you really want a cruiser with power; buy a 2008 LC.
G
I was going to do a 7mgte swap because I had an extra one from one of my supra's but I sold the motor last winter. The 2jz could also work, but I think I will be happy for the time being with gears, exhaust, and a k&n.
