So I installed APRS in my rig via iPad to uv-5r, when I plugged it into my roof mounted antenna it transmitted continuously. So I broke out my favorite fluke and homemade oscilloscope.
Well I pulled everything back to the IGN circuit. The Oscilloscope is grounded directly to the battery and the probe is attached to the ground on the roof mounted antenna's coax. Here is the image.
Now this next one is from my iphone, the scales are switched but its showing generally the same spike. Whats noticeable here is that I linked my batteries and you can see the slight difference it had.
Whats my next step? Start pulling grounds?
I have had an audible RPM dependent click and alternator wine.
