Need help with restaints
Which restraints are the best
  • Total voters
    4
Bad Coco
GOLD Star
Garden Valley, CA
Seat restraint preference
I am building up my rig and finally have my seatmounts and seats installed. I am going with 3" lap belts with removeable 2" shoulder restraints.
I searched but didn't find quite what I was looking for.
Anyone here have experience or input on crow enterprize belts, wescoperformance, Corbeau or other. Any help would be appreciated.
well i can say the the 4 point and 5 point harnesses almost hold you in the seat to well. They are fine if your doing mach 9 and only need to twitch the wheel. but for offroad i find myself constantly hooking only the lap portion so that i can move around and see all that i need to see.
X2.
I've got 5 point harnesses in the FJ40, mostly because my son is usually with me. Even if he is not, I still have the habit to fully buckle in. There really isn't a down side, and in a roll, you want to stay inside the cage.
The ones I have been looking at have removealble shoulder harnesses. I don't see wearing them for slow speed on the trail. Only on the road to and from and when in an I think this might cause a bad hair day spot on the trail.
I used to think this way... but more recently I have started to buckle up fully.. Even when crawling, the full support is a benefit..
belt up, it is only your life ;)
Is it the bird that draws everyone to Crow Enterprize's restraints? They seem to cost more than almost everyone except Simpson, who are also very proud of their nylon webbing. I personally went with RJS Racing because Summit Racing sells their restraints for a good price and they feature my initials.
I might not have phrased the question well. I am going with the full restraint. I'm trying to find out what you guys think the better mfg. of the restraints are. Thanks for the replys so far, Eric
If you have the need to have one or both shoulders free, then get a Crow system with the Rotary Kam Lock Seat Belts. You can have one or both shoulder belts unattached and if you want them secured then click them in like you do with regular seatbelts.
They are all racing approved. Pick your vendor. But none are DOT approved. That is what I find silly.
they are all fairly good.
The biggest factor is the length of the belts and your mounting points..
Some of the less expensive ones are a heck of a lot shorter...
I've got the Simpson ones. Very happy with that choice. They have very wide webbing-4 inches or so. Roughly $100 each when I got them, probably more now. I wish I had a better cage, but the harness is plenty good.
The seat belt harness will depend on the type of seats you have. The more the contour bucket seat you have, you will be able cut back a little on how many harness points you need.If you have wrap around seats the full harness I find is to constrictive.My $0.02
srry thats my fault i jacked your thread at the very beggining. I agree with what everyone is saying the brand is not as important as the cost and fit. go with a good price. the webbing in any of those companies is going to do the job. find one with buckles that work the way you want. Especially the top straps ive got corebeu?spell? and I like them. I use them just like you said, the top straps go on in "bad hair" spots and on the road.
Schroth Racing Harnesses DOT approved to boot!
Check this system out:
and
Very cool stuff.
I really can't see how you can make the argument not to wear good belts, but you really need to build your cage for the belts. Improperly installed belts are probably worse than just 3 point shoulder belts in the stock location.
Diest used to make a "Jeep" seatbelt designed to work with out a bar across the back of the seats to achor the shoulder belts to.
Schrothe makes a bunch of cool belt systems for daily driver cars too. You can buy bolt in systems for BMW, Mini, Subaru, etc.
-Stumbaugh
maybe I better clearify that in no way am i advocating to not wear a seat belt. .. i never said that. what i am getting at is that the after market 4 and 5 point harness hold you in the seat so tightly, which is what they are designed for, that you cant even move forward to adjust the rearview mirror.(unless you have go go gadget arms) the stock belts with automatic tensioners are nice when it comes to that kind of stuff. Because of that, I often use only the lap portion if say i want to turn on the heater or something i cant do it when im strapped in. I just thought that info was something to think over when deciding what kind of belts to use.
by the way the pooflinger is lookin good.
i've had five and four point harness before. i don't wheel hard enough to use them and i find them too restrictive...i'm not real tall (no comments from the peanut gallery;)), so i have difficulty reaching the dash controls and xfer shifter with the harness on. i just use the lap belts.
after having shoulder belts that came completely loose, i'd rather have the kind that are attached to the lap belt. you can put them behind your shoulders if you're not wearing them, but, if something does happen, they aren't flying around hitting you.
My seats mounts are attached to the roll cage which is attached to the frame. I will be installing a bar to go between the B pillars to attach the shoulder straps to.
I am running the PRP daily driver. I'm a big guy if you didn't see the build up picks. I didn't get the wrap around seats.
I plan on using the 3" lap belts with bolt tabs. I intend to use the 2" removable shoulder belts attached with the snap ends so I can remove them on casual on trail driving while maintaining the lap belt.
The PRP seats I have only have one slit in the top. I plan on using the Y or V shoulder harnes.
I will most likely run a 2" antisub belt with snap ends, so as with the shoulder straps, can be taken off of casual trail ride.
Thanks for all the input so far. And thanks Venpick for the compliment.:cheers:
