Just replaced mine. This thread was extremely helpful - the advice to remove the bracket + pump together, and especially the pics of the mounting surface without the bracket on. The bracket mounting bolts all came out pretty easily with basic swivel sockets, extensions, and spanners. Mine did not have the stud in front - just another M10 bolt like the other 3.
I still struggled to get the bracket and new pump assembly back on as one unit - it's heavy, and holding it in place while trying to blind thread the bracket mounting bolts just wasn't working. In retrospect, having that stud to hang the front of the bracket on would have helped a lot.
In the end, I separated the two and mounted the bracket alone with a shorter M10 bolt and lock washer "pre-loaded" into that tricky rear bracket hole that's so close to the exhaust manifold. Then the pump went in.
Here's another pic of what the bracket mounting surface looks like. I moved a lot of ABV stuff but not the smog pump itself.
Toyota PS pump 44320-60071
Woodruff key 90280-05008 (optional but for $3 why not?)
NAPA high pressure/ hard line 7-2142
3/8" power steering return line (2 feet is plenty)
