Hello everyone,
I have a 2006 lx470 with about 200k on it. I have gotten a intermittent P0171 and P0175 codes couple times at random. After the second time I replaced the MAF with a new OEM Hitachi based off of research done on here. Unfortunately that didn't fix the issue but it does run even smoother so at least it didn't feel like a waste. P0171 came back a few weeks later. I hooked up techstream and it showed P0171 and pending P0175. Cleared the codes and drove it around and they came back after about a mile along with all of the other codes. It also had a noticeable stumble from a stop which it had only done that one time before.
So far I have checked the grounds and power on the ECT connector and MAF sensor and they seem to be good.
My guess is it could still be a frayed wire somewhere.
Hopefully someone else might have a suggestion on what to check next.
P0172 and P0175 Rich bank 1 and 2
P0118 engine coolant temp sensor 1 circuit high
P0113 intake air temp sensor 1 circuit high
P0102 Mass air flow circuit low
