Need Help Compression Gauge Stuck
I totally got screwed by my compression gauge adapter. It came unthreaded in the bottom of the tube. Not knowing this I threaded my new plug in. Then I noticed the plug boot was a inch or so high. Pulled the plug and the the electrode was smashed in. Took a pic down the hole and saw the adapter down there. Of course it's at the rear cylinder up against the firewall and plumbing. So I tried backing it out with the compression hose. But no luck. So I thought a little JBquick on the the threads would keep the hose in the adapter. Which it did. But I guess the torque I put on it by installing the plug was too much. The hose is just twisting. In hind site I should have put some JB on the old plug. And screwed it back out easy as pie. But now I have a total cluster fornication on my hands. Has anybody tried removing the plug tubes? I saw in the manual they use a sealant on the tubes. Was thinking maybe I can pull valve cover and the tube out. Then hopefully I can get my tools on it. Any ideas?
I did the exact same thing a few years back, getting my mom's Volvo wagon ready to sell, but I was fortunate enough to be able to extract the adapter with the compression tester hose, like you tried to do. I think there was enough anti-seize still on the threads of the head that saved me.
I think I'd try a reverse thread easy-out extractor or similar. Good luck.
Can you stick a screwdriver in there to try to unscrew it?
Or a pair of reverse snap-ring pliers that spread open when you squeeze the handle. Don't know if they'll reach that deep.
Good Luck!
I did this when I bought mine.
I ended up using loctite on the compression tester and another adapter end and screwing that on and waiting for it to dry.
The correct size EZ-out will remove both the hose end (after tearing the hose off) and adapter easily.
I cut open my other compression hose. To see what I was working with at this point. It's a small diameter thin walled tube. That the hose is pinched against in the sleeve. It so small I would have to use the smallest size ezout. I was planning on doing a valve cover, pHH and replacing all the hardened vacumn lines. So I was hoping I could pull the spark plug tube out of the head. And get my hands on it.
Spark plug tube is a press fit into the head. Not sure you can easily remove and replace it.
One trick I used when in a situation like this, is to "freeze" the fitting screwed into the head, while attempting to unscrew it. I used a can of the PC laptop duster held upside down, sticking the spray tube down into the spark plug tube. It worked - shrunk the fitting enough to allow me to screw it back out with the hose.
Loosen heater valve assembly and wiring harness bracket from firewall. Total 4 small bolts. Pull all forward to allow a really long set of needle nose pliers to reach down inside tube. Have seen this problem/solution several times. You are not the first to have this happen.
It sounds like he really torqued it down good with the spark plug though. It's way more than finger tight. Would the long hollow spark plug wrench tube thing that comes with all our trucks work? You could get lucky and it's similar in size
Just push the rubber plug retainer out first.
But the hose is long.
This assumes there are flats on the adapter or hose fitting of course. Mine has them. Not sure if the op has them on his. This requires cutting the hose of course.
Good idea on the plug socket. It walls are much thinner than a socket. I will give that shot tomorrow. Yeah. Really Fd myself torquing the plugs down. The manual said to use sealant on the tubes into the head. That why I was curious if Incould pop em out with a bit of a wiggle and tug. Hopefully that thin wall socket will fit over it. Keep the ideas coming much appreciated.
Not trying to be harsh but why didn't you just stick a socket down there and remove the adapter without any of the jb welded crap? It already has a provision for that.
The adapter looks like it's th same as a plug. But it's a bigger size and not hardly any room around it in the tube. That's why I like your idea of the thin socket wrench.
