This has all been very helpful and
NLXTACY was amazing and really helped me understand that after calculating your power consumption of all the accessories you plan to power and accounting for the distance of the run (electrical voltage drop increases over greater lengths of wiring) then I can determine my wire gauge size by using a 12 volt wire chart, which is easily found online. He helped me understand the use of a self-resetting circuit breaker and how that is going to mount closest to the battery source and how to take those wires down to your fuse panel. I better understand the need for a fuse panel as it will offer the greatest room for customization and the advantage of using atc fuses that are appropriately allocated to the corresponding accessory.
To recap I currently run a separate mobile marine battery system comparative to the goal zero, except this was put together long before all of this stuff became fashionable. My ARB fridge is powered by the land cruiser when we are driving and then we switch it to the mobile battery when we make camp or park. The problem is that the 12V arb plug has broken and been taped back together numerous times while I waited to address the larger issue of running a power source to the rear quarter panel of the vehicle and switching over to the Anderson SB50 power ports.
Additionally the extra battery is extremely heavy and the long term goal is to free up precious cabin space and mount it in the engine compartment. We currently recharge our second battery with a 120 Watt solar panel, which I eventually want to mount on sliders underneath the k9 roof rack and rooftop tent. As for the onboard air compressor I want to mount this in the front engine compartment if there will be room. So I don’t foresee any real need to run a large amount of power to the rear of the vehicle as I have no desire to install a backup camera, or a winch to the rear of the vehicle.
All of your tips are amazing and essential and here is what I think is happening...
#1. Calculate the power draw
ARB Fridge 15 amps
H20 electrical water system 3 Amps
Dual USB Port charger 4.2 amps
Total: 22.2 amp draw
#2. Determine Electrical Wiring Size
It looks like I will be good to install the 10 gauge wire! Or even bump it up a notch and go with the 8 gauge wire.
#3. Gather Supplies
- Ground Wire
- Gold Ring Crimp Terminals with Color Coded Boots
- Blue Sea Marine Grade Short Stop Circuit Breakers 30amp
- 25ft bonded zip cord 10 gauge electrical wire
- 25ft ½” PET high flame retardant braided sleeve
- Blue Sea 5045 4 Circuit ST Blade Compact Fuse Block with Cover
- ACT Fuses
- Anderson power ports
- Heat shrink wrap
- Crimpers
- Anderson power port mounts
#4.
Find an entry location to run the wires from the engine compartment to the interior cabin and fish through to rear quarter panel PS.
After fitting the wires to the rear quarter panel and setting up the fuse panel can I run these wires to the power ports?
If I'm not mistaken then acording to the above power chart I should be able to run these wires to the anderson power ports and so forth.
Run 18/2 AWG from fuse panel to Anderson power port
Run 18/2 to dual USB port
Run 18/2 second Anderson power port
