Need Driving Lights Suggestions
S. Jersey - New Germany
I want to add driving lights to my front bumper and I am looking for an all around practical and economical solution. Any suggestions and photos would be appreciated.
Lights are designed for specific use, so you've got to provide details on how much you're willing to spend and what your expectations for the lights are (use, conditions, etc). For instance if all you want is a little supplemental urban lighting and your budget is $100, you won't be getting HID pencil beam recommendations.
DougM
Overall my Hella 4000s remain my favorite light - well worth the price. I have LightForce 170s in the ARB now and they are a good light, but they don't have the power of the 4000s or 240s. The ability to dial in the light pattern (literally) is an excellent feature of the LightForce design. The Hella mounting base is a wide, flat plate that can be a problem on tightly spaced mounting tabs, whereas the LightForce footprint is really small.
Once you get used to massive lighting it's hard to go back... I know the concept of $250 or so for lights is hard to accept at first, but I think it's worth it.
DougM
Thanks Doug, point well taken. I do a lot of deerhunting and there are some deep puddles I need to go through on occasion. Actually on the way into the deer woods early in the morning I try to enter without any light at all, but on the way out I will use light. For the most part I want to add some kind of lighting to my bumper with the option of having extra light when I need it.
I'm pretty happy with the Warn SDB-210 .. they come with 100/90 but are H4 so you can swap 'em ..
Rod,
I have been a lighting fanatic for 20 years and have a system that I think provides tremendously effective light at reasonable cost, provides flexibility as to output, and importantly is bone stock reliable. Hella 4000 fog beams on the bumper, and the John Deer/Hitachi HIR bulbs in the factory 80 headlamps. On wide open (no oncoming traffic) NW roads I have long distance lighting (reflective range over a mile) and a wide swath of powerful light as well when the high beams and Hellas are on. On a trail, the fogs to me are the best beam pattern as they are like a powerful area light and of course in foul weather this is the pattern to have. My 93's Hella 3000s (predecessor to the 4000) have 185,000 miles on them and they're dead reliable. The 4000s on the 97 have 90,000 miles on them.
As a variation, consider getting a pair of 4000s, but one fog and one euro beam. That's the format I originally went with on the 3000s - wiring each to its own switch and relay. These are big lights and a single fog easily did the job. I put a 100w bulb in the euro beam and had dazzling output. When the light covers are on, they look identical. When they're off, only another light fanatic would note the cool setup. After a year or so I found the euro was simply too bright for anything short of racing and popped a fog in its bucket, but for your use it may be appropriate.
If you want to mount 4000s on the factory bumper, I'll PM you the exact measurements so the lights are as close to the grille as possible and as far apart as possible without blocking the high beams.
DougM
Thanks Doug, very informative, you should have been a Pitchman. I will be mounting the lights on too my Slee Shortbus bumper not a stock bumper. I guess I'm looking for a set of modest looking lights with good performance but not a set which gives the appearance of being well endowed. I don't mind spending money for quality but like I said earlier I want to keep it practical too.
Hella 4000 fog beams on the bumper...
Doug (or anyone), I don't know much about lights and am in the same boat as 80 Cruiser Rod; planning on mounting some to a Slee Shortbus.
LIGHTS:
Question 1: Are you referring to these H12560001 : Rallye 4000 Halogen Fog Lamp? (Here they are sold by Hella on Amazon)
WIRING HARNESS:
There is also a recommended Hella 148541001 Rallye 4000 Wiring Harness.
Question 2: Is this Hella harness a good idea to buy or is a D.I.Y. wire/switch harness just as good?
I suppose if I chose not to buy the Hella wiring harness and make my own, I wouldn't install a relay (I'd run 12ga wire to a switch and that's it).
Question 3: How much of an advantage would a relay be (i.e. smaller wire to the cab for an easier install and less resistive loss; not sure) ? :hhmm:
Thanks, all.
LIGHTS:
WIRING HARNESS:
Thanks, all.
The lights in the amazon link are euro beam, not fog.
Not a good idea to not use a relay with these lights. they use a 100w bulb that will burn up the switch. I picked to just buy the wiring harness with mine since it is all pre-wired and mostly plug in a play.
My set is coming in tomorrow, ill let you know how the install goes. Normally hellas wiring harnesses are top notch or atleast in my previous experience.
Nice catch. The correct link for Amazon (I'd try to support my local 4WD shop, BTW): Hella HLA-H12560001: Rallye 4000 Metal Fog Lamp
The specs from Hella give 55W per light. So, the combined power of the pair would be 110W at ~9.2A on our 12V system. Yeah, that's a bit of current to be running up to the dash.
Great; thanks for the speedy reply, too.
Ebay always has good prices on used lights. Sometimes they just need a new bulb.
I love my IPF 900s with 130W bulbs on my bull bar.
Up top, I've got 6 PIAA 520s in the front and 4 PIAA 510s in the rear.
As stated, it really depends on what you need / want.
Hella 4000 on stock bumper. Wiring them up was simple with the hella wiring harness, the most difficult part was figuring out how to make them come on and off with the high beams since toyota decided to use a different positive negative setup on the highs. They are pretty massive as well and the light output is amazing.
FYI on amazon they are not sold as a pair. You need to order 2.
Thanks again Doug for the dimensions.
Cool. Glad it worked out. Now you've just got to straighten out the covers so you don't look like you're from Alabama.
Whups - just noted the license plate....snicker.....
DougM
LightForces are the lights of choice for me. Not the best picture, but I am running two XGTs on an ARB bumper. I've also owned the 240 Blitz and like that the light can be focused like a maglight from a spot beam to a wider driving beam pattern. The clip on colored lens covers are also nice as you can tailor the light for your specific driving conditions be it rain, dust, snow, fog, etc. Not sure about the other lights mentioned, but no part of the Lightforce lights are metal that will eventually rust or glass that can break. They are not the least expensive light, but in the case of the Lightforce's you get what you pay for and then some.
Lightforce
I chose the IPX 900XS HID's with Remote Ballasts and IPF Fog Lights for the ARB Bumper and Hella 4000xi Compacts with internal ballasts for the roof rack. I also went with six (6) PIA 1500's on the roof rack.
However, if I was looking to save money, I would go with the Hella Rallye 4000 ... they are very nice as well.
This is a pic of the lights on my rig with everything roughed in...not yet wired. Hoping to have it all done in 2 weeks or so.
I use these 100W cheapies and they work great. I'm not overly worried if they get damaged, or stolen seeing that I live in an urban environment, because they're about $10 each. Most of us end up wiring them up without any sort of kit since we all like to go bigger and better than manufacture recommendations, so no need to buy a set with a cheapie switch and small gauge wiring.
Go to Autozone or your local junkyard, buy a relay for $5, use the rest of the 14 or 16 gauge wire you have laying around, and snag a genuine Toyota switch for one of your empty dash blanks and now you have a factory looking setup with good lighting for about $25-30.
Northern Industrial Off Road Lighting System Spotlight — 12 Volt DC | Work Lights | Northern Tool + Equipment
