Need diesel help in Victoria BC
Hi,
My old and trusty HJ60 is missing very badly today. Totally stock Canadian spec. Lots of blue smoke that smells like unburnt diesel. Didn't get better after letting it run (been having some glow plug timer issues).
My DIY compression gauge is back in Ontario. Hoping that someone local has a compression gauge that I could borrow. I'm hoping it is a stuck injector or something. Reason I 'm suspecting (hoping) the injectors is that I replaced the nozzles about 6K km ago. Replaced with German Monark. Was running OK two days ago. Filled up with diesel a week ago at my local Shell station so not suspecting that (yet).
I have a spare set of injector bodies with me. No nozzles. May need to find injector shop that can sort things out if necessary.
Thanks,
Mike Ayukawa
Mike
I'm on the island but up in Ladysmith. I'm not an engine mechanic. My first instinct would be fuel filter too.
Certainly sounds like a fuel problem. There is a Vancouver Island Club page. Majority live in Victoria area,
so I'm going to publish a current list of businesses the guys put up within the last two weeks. If you start
a 'Help' thread there I expect someone right there might be around to help you out.
Suppliers, Manufacturers and Services
I do have a spare fuel filter ... hmm. Maybe will first try draining the fuel separator. Both easy and cheap so a good place to start!
Hi,
Thanks,
Mike Ayukawa
So did you get this fixed? Kind of curious as to the solution you found.
