Need CDL switch help.
My 1995 FZJ80 had a CDL switch installed by the PO. I know that when we initially tested it there is a light that went on with the button depressed.
I tried it the other day and nothing happened. Also nothing seems to happen on the dash whenI put it into low. Is there something I'm missing? The vehicle doesn't have the 7 pin mod at all.
Without the 7 pin mod, it needs to be in low range and the button pushed for anything to happen.
{EDIT - What I posted right here is NOT correct - read below for correct info :) Strike this --> Actually, with a CDL button you can lock the center diff in high range but you will not be able to lock the rear or front lockers until you put the tcase in low OR do the pin 7 mod.}
So supra, yes something should happen when you push that button. First, the center diff icon should come on and the ABS light should come on ('95 has ABS brakes correct?) indicating the ABS brakes have been disabled.
The same thing should occur by putting the tcase into low gear, with the exception that you will also be in low instead of high.
Since your not getting indication by doing either then either your lights are out (should be able to test that by checking to see if the lights come on when you first start the truck) or the center diff isn't engaging.
If it is the later try going to a dirt road or parking lot and shifting in and out of low numerous time to "exercise" the center diff. Move forward and back as well and see what happens. If numerous attempts at that fail to do the trick then search on the center diff as I know there have been numerous threads on this very issue with good information on what the fixes were.
I checked it today and the ABS light comes on when the key is in the on position but not the CDL light.
I pressed the button and nothing changes.
I shift into low and other then being in low gear nothing changes, no lights and the diff does not appear to be locked.
I know that I have had the CDL locked twice once when I testdrove the truck and once more about 3 weeks ago when I tested it myself. Both times the CDL locked quickly without any problems.
My understanding is that pin7 mod allow you to unlock the CDL while in LOW. Without pin7 mod, one can still lock the CDL with the CDL switch and then engage the F/R lockers in HIGH. Please correct me if I am wrong.
Here is everything I can think of to check:
- CDL fuses
- CDL functionality with no light (bulb)
- CDL connection at the button
- CDL connection at the actuator (could be lose position sensor or electrical control plug)
- CDL actuator being old and busted (needing service) - search for CDL actuator cleaning instructions
Beyond that...???
I do not believe that the CDL lamp illuminates when the key is turned to on. The individual red locker lamps should though.
I think your connection on from the harness to the differential itself might not have a good connection. I would unplug it from the center diff, spray it out with electrical cleaner, and see if it helps. Search CDL and you will find much more information on how to diagnose the problem.
Adding the switch allows center diff lock/unlock in low. Removing the pin 7 wire allows it in high. It also all keeps the proper shift patterns for low/high in place.
Eh....I get so confused on the whole issue ;p - This doesn't help the original poster but in an attempt to keep the correct information flowing on the CDL and the pin 7 mod and seeing how I muffed it up...
Here is probably the best thread I've seen explaining it. I just can't ever seem to keep it straight in my noggin:
https://forum.ih8mud.com/showthread.php?t=136747
RT's excellent detailed post (#21 from the above thread)
OK lets back up.
on a stock FZJ80 there is no CDL switch, the CDL locks up when the T-case is shifted into low.
There is a switch on the T-case near where the shifter goes in, after the shifter has moved from the high range gears to the low range gears this switch sends a signal to a relay, the relay see's this and powers the CDL to lock, that signal comes into the relay on a blue and black wire to pin number 7 hence the name of the mod, the only way to unlock the CDL is to go back to high range so stock you have two options,
High, CDL unlocked
Low, CDL locked
When you add the CDL switch you can then hit the switch to lock the CDL at any time, so you can lock the CDL wile in high range, so now you have three options
High CDL open
High CDL locked
Low CDL locked
But you still do not have the fourth because not matter what the switch position when you shift into low the signal travels down pin 7 and the CDl will be locked,
If you remove the pin 7 signal than that that relay will never see the T-case go into low so it will never automatically lock the center, now with the CDL switch and pin 7 mod the only way that the center ca be locked is via the CDL switch so you have 4 options and complete control of CDL operation.
High CDL open
High CDL locked
Low CDL locked
Low CDL open
T-case gear range and CDL operation are now completely separate and under your control instead of tied. I see why Toyota did it this way, would be hard for the average person who is used to only cars to get their head around a low range much less throwing the mysterious center differential thing in so they took it out of the drivers hands and made it automatic.
If you did the pin 7 mod before getting a switch then you could not lock the center, you would have two options
High, CDL open
Low, CDL open
If you have front and rear lockers you would not be able to lock those either as they require the center to be locked.
Personally I like the real CDL switch even if pricey if only because it has the backlit CDl symbol on it that matches the light, having two hazard switches seams improper to me.
I have the exact same symptoms. It has worked in the past. I'm also positive that the CDL light chould come on with the ABS light at startup. I'm planning to check the wires to the t-case first and go from there.
Negative.
The CDL light does not come on (in a 94) when the key is first turned on.
So I removed the possative lead from the battery to do some welding and once reinstalled it works just fine. Kinda odd.
