I need to know the inner diameter of the bushing eyes on upper and lower rear control arms.
Can anyone supply the exact dimension?
The hole that the bushing is pressed into.Where the bolt goes through or the entire rubber interior of the bushing itself?
... The machinist told me that the durometer of the bushing material needs to be considered when deciding on how much interference there needs to be for a proper press fit.
I know the dimensions of the bushings because I have 4 new ones on my workbench. And, I agree with the rule of thumb. If I were machining them myself, I would bore for a .002 interfence fit but I thought I would attempt to find out the size of the factory bushing eyes.The durometer of the bushing material is irrelevant, they have an outer, metal sleeve, so metal to metal press fit. But yes, you need the bushing hole ID.
Since Beno told you the bushings are 55.5 MM, and Tools told you that durometer doesn't make any difference, I'll jump in and add my 2 cents as a Machinist.
The general rule of thumb for a press fit is .001 press fit per Inch of diameter. So since the bushings are about 2 and 3/16 of an inch in diameter, you'd want to make the bore in your control arms around .0022 of an inch smaller then the O.D of those bushings.
Now that's a general rule of thumb, and as a "general rule of thumb", there are exceptions to every rule.
Case in point, i just machined, and installed some bronze connecting rod wrist pin bushings in a customers 9 cylinder radial aircraft engine, they had a .005 press fit, and they were only 1 inch in diameter, that press fit spec came from the engine manufacture.
Funny thing was, even with that .005 press fit, the engine manufacture still required those rod bushings to be swedged on both ends with 5 tons of pressure from a Hyd. press.
I guess it could be said, the engine manufacture really wants to make sure those bushings can't move in those rods, but high press fits like this are really outside industry norms.
So what is your opinion on using any kind of lunrication for assembly of parts that are designed to have an interference fit?
Thank you. That is about what I was expecting it to be.Had some time waiting on our victim this morning, so pushed a bushing out of a lower OBD2 arm. They are not exactly precision round, so about 2.155" to 2.160" or 54.75mm depending on where it's measured.
I use a product made by CMD on all of my press fit jobs, It cuts way down on the force necessary to press two items together. I've also found that upon tear down, and inspection of those items that were pressed together that CMD's use greatly reduces, or eliminates signs of metal Galling, or scoring.So what is your opinion on using any kind of lunrication for assembly of parts that are designed to have an interference fit?
