need 18mm bolts
Hello. i need to get my hands on (2) 18mm x 140 (ish) bolts for my 1996 LC. They are to replace my existing front control arm bolts.
i have been searching everywhere in my town (Reno) and online with no success.
any ideas out there? anyone know of a place where i can get buy some?
thanks,
keller
thanks,
keller
I've got some extras if you can't find any.
-o-
Try a big rig type of store. We have Fleet Pride out here on the East coast, not sure what is in your area. I would think that any larger truck company that handles trucks made in Japan (Iveco, Isuzu, etc) may have larger metric nuts and bolts. I also have a tractor store that I have had good luck with that sells nuts and bolts in the 1" range and has a large selection of metric stuff in those ranges as well. If you don't find anything by Monday I will stop in and take a look.
I need bolts for the front that are 1'' to 1.5'' longer than stock...=140mmif some one wants to sell me theirs, I would be very happy since my rig is stuck in the driveway until I find some. thanks
If you need the ones on the front of the arm where it attaches to the axle just use 5/8" bolts. I actually use frame bolts in that size of a fine thread with a flange nut.
While the 5/8" bolt measures slightly less than 16mm it is actually larger than the stock bolt because the stock bolt has no shoulder.
nope, front side where it mounts to the frame.
"front side" infers that you want the axle housing end. That end is 16mm.
You want "frame-end front arm bolts" which are 18mm.
if you need longer bolts and that are 10.9 grade, then call metric & multistandard out of ny, sorry dont have a no. but they are on the net. what i got when i put the drop brackets on were the 18x 120mm x 1.5pitch they are actually the same size that MAF sent but werent cut back and they are the 10.9 not the 8.8. i think they were about $7-10 i forgot and the invoice doesnt show the price.
he's looking to mount a set of my sliders.
the rear bolt where the control arm meets the frame.
metric is a pain to find in that size (18mm dia)
i'll post up or e-mail asap after i get back from the shop.
probably 12-1 pm mountian time.
Jim is correct. :) i am mounting his sliders, which i bought used and the shipping company managed to lose the bolt package. brilliant.
anyway, 18mm x 140 is nearly impossible to find, but i can't bang the 3/4" bolt through the ball joint sleeve. 3/4" calculates our to 19mm, and 18 mm is actually very close to 11/16", but i'm not seeing those anywhere either.
jim, when you install the 3/4" is it a real bugger to get them in, or do the slip right in? Could the 1996 model be a little different for some reason?
for everyones info...
Jim's sliders went on easy and fit very well. i am impressed with the engineering on them and how well the tuck into the frame and bolt.
well done, Jim.
:bounce:
i don't think the years differ.
i know the hole in the plate is 3/4"
let me get to the shop and i'll mic it. the bolt just might be a hair under 3/4
we have used the new bolt to push out the factory bolt.
i'll be in touch :cool:
For the record
There is no such thing as 11/16 diameter bolt. If it is measuring 11/16 it must be metric. I own a fastener distribution company in Houston. When I get to the office tommorrow morning, I'll see if I can find the 18mm x 140 and let you know.
