My steering is loose!!
Alabama
I have a '79 fj40 that I just purchased recently. It has a positive thing and that is that it has hydraulic steering which I can turn with my pinky! However the problem is that the steering wheel is loose. You don't have control of the car at higher speeds. I have to turn it 2 inches either left or right before it actually starts turning the wheels. It doesn't need alignment I don't think... My thought is that it is the gearbox??? or maybe the hydraulic steering??? Please help me on what i need to do!!!!!!!!
check the center arm up front, in the corner of the fram rails, the rag join, there is alot the can be loose.
With the cruiser in the drive way running, have someone get into it and turn the steering wheel left and right while you are looking under the hood at the steering rod. If the rod is moving when ever the wheel is turned it is most likely from the rag joint forward and you will need to see where the play is starting at the rag joint, box, relay rod etc. If you can turn the wheel and the steering rod does not turn right away, I would look at the wheel mount as Poser suggests in the cab.
Get if fixed though since steering is one of the more important systems.
Pete
try whether tightening the play in the center pin helps any (the cone-shaped thing at the driver side front frame).
That's what it's called, the steering has "play"! I'm not really that good with being under the hood and all, no much of a mechanic, if you guys can be a little more detailed. Thanks
It would be most beneficial to you, if we knew what you had for a steering system, enter the pics....
You have used enough terminology that could give anyone reading through this the idea that you could have a stock Toyota power steering system or one of the many other options for power steering, which all have different little issues about them that could be contributing to your problem, or you could have a full on hydraulic set up, or ???
Its hydraulic steering for sure, its too dark outside to take pics now, i'll take the pics tomorrow, please stay tuned and reply tomorrow, thanks!
Would toyota dealership be a good place to take the rig to have steering fixed, if not where do you guys recommend because i dont know if i would be able to fix this by myself.
Poser said:
Welcome.
I would look at the nut between the seat and the steering wheel.
Good luck!
-Steve
seems that in every rig that i drive, the nut between the seat and the steering wheel is the problem =)
when you say the nut between the seat and steering wheel, could you take a pic of that because i cant find the nut. also you are talking about play in the steering right?
That sh**t is funny:bounce2:
Do you have a mirror?
Take a long look in the mirror and post up what you see.
I just went and looked at the area above the brake pedal, and saw the rod that comes from the steering wheel and goes toward the ground, which is bolted with four bolts all around. If that is what you are talking about, you are wrong because the bolts are tight. It not the steering wheel that is loose, it's just that the steering wheel has "play".
