my member is stuck
Bozeman, MT
As the name suggests I am having some seperation problems concerning the third member. I am trying to remove it from the axle housing so that I can transport it easily because I'm going to weld it and put it into my cruiser. But I cant seem to get it out. I removed all the bolts and took the gears out and the axle shafts out. Then after a while I just did some whacking wiht a hammer and that didnt budge it either. So is there some connection I'm missing that is holding the 3rd member in there still or is it just that stuck? Thanks.
They get really stuck. Put your floor jack under the nose of the diff and put some pressure on it. It will eventually break the seal and then you can pull the diff off. If the bolts are gone and the shafts out, there isn't anything else to hold it other than the 30 year old paper seal that has glued itself to the mounting surfaces.
Axle on jack stands, pinion down. Put something soft like a brass drift or wood on the carrier bearing caps and hit with the biggest hammer you can. Just needs a little brute force and ignorance.
Remind me to never let you work on any of my stuff. I suggest that you don't hammer on the bearing caps whether or not you are using "something soft".
What works for me is the jack method if its in the vehicle. If its out like yours, then just drive a screwdriver or sturdy scraper or putty knife between the 3rd and housing. Don't go over-board. Do one area a little and then move to another area, once it breaks the seal on one side the rest will come of easily.
nuclearlemon said:
cherry picker to the pinion flange and let it hang...the axle housing will drop eventually.
I like Ige's idea, you might help it along with a heat gun. My oilpan was stuck like a MOFO, I left the engine hanging by the oilpan and it did not come off.
Heat gun did the trick.
Ed
Well, using a little common sence. I should have wrote hammer on the bolts securing the bearing caps. I have never had to use a lot of force (never enough to mess up a bearing cap) while using this method. Sometimes it is all that will work without messing up the gasket surface and breaking tips off screwdrivers. I'm going to pull mine out this afternoon to fix a broken pinion and put on an axle wrap bar. I'll let you know if I mess it up. :D
with the axle out, and having the luxury of a cherry picker, I put the axle under the picker legs, bolted a strap to the pinion flange, then jacked the picker up and popped the diff off the axle. worked like a charm.
-Dustin
Flyinglow, thats exacltt where I hammered on it. I have these polymer rods that my dad got for me from bowflex. We lived where they made the bowflex's for a while. So I have like all different sized diameter rods and I set one of them on there and whacked the heck out of it. The polymer will bend in before the metal gets bent or warped so it works great.
just the title made me laugh! Co workers looked around to see what was so funny, so I started to wistle
Good to hear you got er out. That 3rd is a pretty big chunk of cast iron, especially where the carrier mounts. I think it would take a lot to mess er up.
Cast iron isnt as strong as you may think thats what the bellhousing is too and I had to bust one off with a sledge due to the pilot bearing getting the input shaft from the tranny stuck. And it only took about 3 or 4 hits to bust a hole in it.
