my head is warped
I have a 96 lx (factory locked, ome, 295 bfg) that went to the dealer for a HG replacement (diagnosed by lots of time reading mud posts) . The word is that the head is warped and needs to be replaced. The service manager had the machine shop do two passes (one last night, and one this morning), and they couldn't get it within tolerances.
Question 1: Is there a chance that more passes by the machine guy could get the head flat? (I am not worried about higher compression as I live@ 6000 ft)
Question 2: Where do I get a head for a lot less than the 3k the factory wants?
Thanks for the help, I am tired of driving my wife everywhere.
Joe,
I'm kinda surprised the head is warped, frankly but unless you want to physically go get the head and bring it to a machine shop for a second opinion......you're kinda hosed in terms of evaluating this turn of events. Informationally, I had .010 taken off both my heads just for more powah. How much did they take off in their efforts so far and how far out is it? Do you know what the spec is and do they and are you both correct?
I'd consider darkening the doorway of the machine shop to see what they say versus listing to the SM tell you it will be another $3k. I'd also talk to Robby here on Mud as he may have some heads available.
DougM
The SM said something about .018 being minimum. I will continue forward with contacting the machine shop. Anyone else out there had experience with shaving the head?
Not that 22RE or a 3VZE is the same as on 1FZ but I've built many a Toyota engine, 3VZE's that had headgasket issues and thus smoked bearings, and I've never had any issues with heads being so warped that they needed to be replaced. In fact, I've never even had a head machined and three of my rebuilds (97 FZJ, 88 3VZE, 94 3VZE) were sold to friends/family the only one I don't have tabs on is the 94, which my buddy put some 60k+ on and the motor was perfect when he sold it.
Unfortunately though at this point you're kinda between a rock and a hard place, but I'd agree that seeing the machine shop that's doing the work might help. But it may be moot and even if you take it somewhere else and they give it a clean bill of health I would bet that the stealership will pull the ole "well, we can't guarantee our work" song and dance.
You also might want to post your location and see if anyone has a good machine shop recommendation.
I'd be curious to hear if anyone else was told by a reputable machine shop that their head was good for nothing but scrap. You ought to start a thread with that as a question.
head ache @ the dealer
I haven't been to check out the head at the machine shop, or gone to the dealer because they are an hour and half away. I am in Ketchum ID if anyone knows of a good machinist I can comparison shop with. The LX is in Twin Falls. Are there certain parameters that the dealers have to adhere to that are so stringent they force you to buy new factory parts? I have only heard good things about Wills Toyota, and the Service Manager quoted me 1300 for the HG job which I thought was reasonable. Now I am kinda ***ked it seems. Thanks for any input.
The FSM contains all the specs for measuring it. I am sure you can ask the machine shop for the measurements. They should provide that to you. Once you have those, you can make the decision. If it is out of spec, I can see why the dealer would not want to use it, since they have to guarantee the job and go by the book.
I haven't been to check out the head at the machine shop.... because they are an hour and half away.
A telephone conversation with the machinist might prove insightful. Give the service manager at the dealer a ring and ask for the number. The conversation is worth $3K at least.
Not to be pessimistic, but don't count out the possibility that the machinist messed up and is covering the mistake by blaming warpage.
Overheated?
I don't think it overheated. but I have never overheated a car before. There was DEFINITE antifreeze infested exhaust. No question. No malted milkshake. Sipping antifreeze no question. Adding oil yes. Temp gauge normal, but I wasn't driving.
No drips out the bottom of the car, it is garaged. Heater was abnormal, wouldn't kick for a while. Idle was sometimes rough. My wife heard a "clunk" or "pop" and drove it home( 1mile) after that. Then it wasn't driven. Towed for 276.00 to the dealer.
Has ANYONE warped a head before?
Idaho Doug if you're out there, where are you located in our glorious state?
Ok well I've never done a FZJ block rebuild before. By the time I stopped doing rebuilds there wasn't a single one that came my way. I called my mechanic (Enterprise Import Service) and asked him about this yesterday. He called me back to day to say that he has never had to have a head surfaced before. Even if it over heats. He said that he's needed to do a handful of 3FEs but never the Z.
So in my mind, seems kinda suspect. If it were me I would drag in the FSM and tools and check for myself.
Joe,
I'm in Coeur d'Alene, so several hundred miles away and no help. Too bad because I have the most amazing cylinder head shop locally. Also, worth noting that neither of my heads were warped either. I think you should find the spec if someone has it here handy, then an anonymous phone call to the service dept to ask who they'd recommend to work on the head of your friend's Supra and you'll likely have the phone number where your head resides. I little chat with the shop and you'll know perhaps enough to make a decision on this.
DougM
Support appreciated
Now it seems that I have some back up to bring to the machinist and the manager guy at the dealership.
I will make the calls in the morn, ski with pops in the afternoon as he is out Sat morn, and update the helpful of monday eve. (my computer has been known to rest on the weekends)
chow mein
Here's what the FSM says. BTW, the "X" doesn't mean don't do it. It just means that's how you are supposed to lay the straightedge to check.
