My head gasket replacemtn thread.
I am in the middle of a head gasket job on my 94 and figured i might as well do a short thread on it. This will not be a detailed "how to..." thread. There are several of those from people a lot smarter than me. I just want to share my experience with it and a few things i noticed.
So here is the back story of why i did a HG. I bought a 1994 with 185,XXX miles on it about 2 years ago. Ran great but no PM done and throwing code 25 and 26 from time to time. I did a ton of PM including new O2s relocated to the PAIR area, PAIR removal (obviously) and EGR removed. No codes for the last 25,000 miles. Truck ran great. So why do the HG?
1. Truck did burn oil, around 1 quart every 800 miles. I was told it was probably valve seals.
2. I had a digital coolant temp gauge installed and noticed it ran "warm" on the highway, 208-212. On one of my cross country trips in the summer on long highway uphills fully loaded the temps climbed to 223 at one point. I stopped in had it looked at by one of the Land Cruiser authorities and they saw VERY small bubbles in the coolant tank. Nothing major but it was there.
Edit: I broke that after market radiator wheeling and replaced with a new OEM. I have never seen over 199 deg since. Cooling problem fixed.
So i started planning for a HG job and researching it. I figured i would do it on my term, in my shop at my leisure. I lined up a 2nd vehicle, got all the parts from Beno. I located a machinist that has done MANY LC heads and both ACC and Beno recommend.
3. Reason 3. My EGR pipe developed a lead down by cylinder 6. Why did it crak? i dont know. I had removed the EGR and capped the pip. It is possible that i stressed the pipe or twisted it during the removal. It might have been totally my fault. But this was the point that i said "well might as well do the HG now".
So i parked it in the garage and dove in! Over the last two years i had collected the FSM, the HG DVD, all the OEM parts and a talked to the machinist, Beno and the guys at ACC. I was as ready as ever.
Look forward to seeing you tear into it Dana!
There were a few things that made my job easier. First and foremost i had a 2nd car and lots of time. The truck had never seen salty roads and was 100% rust free. Every bolt always comes out with a nice clean "snap". Also all the previous PM meant that i didnt need to do as much "while you are in there like the water pump. The PM also meant a lot of nuts and bolts had been broken free and removed just a year or so ago. Things came apart nicely.
Also i had already removed the PAIR system and EGR. Both gave me more room to work and meant one less thing to have to remove. Also i was just about to install my 2nd batt system. So i had a 91 battery tray on the passenger side in place that makes a nice tool holder.
I am very short, 5'6" 130 pound. I tend to work better in tight spaces than leaning over the truck. So my basic plan was to start disassembly on the passenger side and work around to the driver side. I removed the slee washer bottle assembly, entire air cleaner assembly and intake hose. This was key for me. Now i could climb in and sit in the engine compartment right where the air cleaner was. This worked VERY well for me. T removed the throttle body and cables and then started on the front.
All i removed from the front were the coolant lines, alternator, alternator bracket, hard coolant pipe. I never even felt like the battery, battery tray, fan or anything was in the way. Since my radiator, water pump, hoses fan clutch oil and everything was all ready done I didn't even touch it.
Drive side is the bitch. The main thing is the intake. I did it just like the DVD says. One thing that i did differently that worked for me was the last two bolts holding the two halves of the intake together. The last two closest to the fire wall are tricky. The DVD uses a LONG extension and two people. I found that i could lean my back against the inside of the tire and go in from the side where the rubber skirts are. This let me use a short extension and i got all the bolts/nuts out with relative ease. That position gives me really good access. that is how i did my PHH in the past. But i think a lot of that is due to me begin so shrimpy.
The hardest part of the manifold to me was the two nuts/bolts holding the lower intake to the head. The two near the fire wall were really tricky. But again i sat in the engine compartment and could lean right on the valve cover. Got them off with a wrench and a pipe slid over it.
Over all i think it really helps to sit in the engine compartment.
Head came off next. Nothing special about that except that it is a big heavy SOB. Two person job for me for sure. To my untrained eye the HG looked good. The pistons had some white flaky scaly deposits on the. I figure maybe it was all the oil it was burning. Some of the exhaust valves look really "gooey" on the runner side. Again maybe oil build up.
poor picture of build up
The best part, cylinders still have factory cross hatching and no scoring or damage that i could see!
The picture looks a little messy because i had just slimmed some oil in there on the walls. I was calling it a day and dint want any rust forming.
All cleaned up and ready for install. Looking good for 222,XXX miles.
Back from the machine shop. Turn around was about 7 days. New valve guides and valve seals installed. All the normal good stuff done to the head. They only took .010 off to clean it up. Looks really good to me. I have to install such a nice looking head in such a dirty "trail truck".
looks a little better in there!
Working alone this is how i got it in. It was a pain but it worked for me. It was overkill but i didnt want to risk dropping it and i had the hoist on hand. So why not!
I found this interesting. The old HG is clearly different from the new one. To me it does look like a design change. Lets hope it keeps them going strong. Look at the gray area around the cylinders on the new one. I dont see that on the old one.
Got it in place! I had time to get the head bolts installed and just hand tight but not torqued. Tomorrow morning i will hopefully get them torqued and get the cams in. My plan is to just follow the FSM about torquing. Is there any thing else i should know?
Got the head torqued and cams and timing chain installed. Dam those head bolts are tight and the cam caps felt not tight enough at 12ft/lb. But that is what the FSM said.
Tuesday i will shoot for installing the chain tensioner, valve cover, motor mounts and lower intake manifold.
Clean internals, dirty exterior!
What's not to like? :clap:
that is the story of my truck. i think it gets washed twice a year. Sometimes i put a sprinkler under it after wheeling. But i keep the oil, air filter, belt, plugs and all that fresh. Electrical connections get dielectric grease around them along with other regular PM. I have fixed most every leak except for a little weep from the rear main or rear arch and i am not going after that one. Keeping it clean is nice to work on and see things when things go wrong.
I know you are really talking about the inside of the motor being clean. But honestly the outside is not as bad as it looks. Most of what you see is the orange stain from the Moab mud. No rust at all on that motor or bolts.
Yah, I use the snow to 'wash' the brine off the windows and exterior panels. One to two times during summer she gets a rub with wax. Gonna have to keep up with a fluid film or some sort for next winter. Last month, a few days after a drive, I noticed bright orange on the drivelines, pretty aggravating that the road dept. here thinks salting / mag chloride is good policy.
I have not kept this updated. I got the cams and timing rears all in. Painted the valve cover with some VHT wrinkle paint. The valve cover turned out OK but not perfect.
I spent most of that day doing the front motor mounts. It was a bitch for no good reason. Somehow i like to make a simple job complicated. But eventually i got a set of nice new OEM motor mounts installed.
I made a block of plate for the EGT on the head. I realized that i installed the head before getting a good picture of it. This is the best i could do. It blocks where the EGR pipe comes of the head near cylinder 6.
This was actually very rewarding. I replaced all the old crunchy fuel injector plugs with nice new OEM plugs. I think 5of my 6 old plugs had broken clips.
What did you torque your valve cover bolts to? I went by the general consensus of "good and snug" and mine backed out in a few months.
I'd recommend using the 6mm torque value from the FSM.
Looks great!
I think you are right. when i removed my valve cover i found a few that were really loose from the last time i had it out.
Some goodness from WitchHunter. The screens that came out of the injectors did look like crap. One of the injectors did originally test "fair". After they did there work they all matched up very nicely.I will try to scan in the paperwork.
I did manage to get the lower intake installed. I think this was the hardest part of the head gasket job. There are a few bolts that are just really tricky to reach. I also got the cleaned fuel injectors installed with all new OEM rubber gaskets and new wiring harness plugs.
Looking forward to more pix!
