My first Piggy
Discussion in '40- & 55-Series Tech' started by 63beastly, Mar 2, 2007.
  1. 63beastly
    63beastly
    3
    Mar 1, 2007
    My first 40
    Hope this is the right place, This is G from San Joser I just bought my red 63 FJ40 for 4500, original paint, pretty good but the rust is just starting to get at everything as I got it from some dude in the city by the ocean. It has a 'vette motor, 3 speed turbo 350 trans, reversed front shackles, 4" spring lift? Still sprung under, power steering, front disk, f'd camber, it has like an inch of toe but dances like a drunk bear on highway ruts, could this be the loose tie rod ? Great potential but no follow thru, wiring is tweaker fab special, brakes not working right, carb secondaries not dialed, carb choke needs tweaking, headlights sometimes? work. ( do the pull switches go bad or is there a relay for the Hella headlights? (running lights work consistently. I think it needs a head to toe teflon rewire with heat stink and wp connectors, has a teeny short somewhere with key out. Nothing a little TLC cant fix. Other than that it gives me a big sheeyot eating grin every time I drive it. Thanks for all you posts, I actually knew what to look for after lurking here for a couple of days. Looking forward to pissing yall off with stupid questions soon!:flipoff2:
  2. tlcruiser66
    tlcruiser66
    710
    2
    Sep 4, 2006
    Western Wa.
    When you want to replace that wonderful wiring nightmare you've gotten yourself into, go with EZwiring.com, their prices are half that of Painless and you get the same quality. As for the steering, are you still running the stock config or did the PO convert to Saginaw? When you say F'd camber what do you mean, maybe post some pics...:D. Can't wait to see what your new ride looks like.
    Welcome to Mud,
    Kevin
  3. projektdotnet
    projektdotnet
    1,839
    Sep 26, 2005
    Port Orchard, WA
    X2 on everything about EZ vs Painless...Painless=extremely painful!
  4. clemson55
    clemson55
    4,263
    5
    Jun 6, 2004
    Hampton, VA
    You need to change the threads name theres no pig content. I got my hopes all up for nothing. Congrats on the 40 though.
  5. LRIwater
    LRIwater SILVER Star
    281
    10
    Oct 16, 2003
    San Diego, CA
    X2 on Clemson55's comment!
  6. cruiser_guy
    cruiser_guy
    11,196
    29
    Jan 20, 2003
    Wherever the truck stops!!
    x3 on Clemson55
    The term "Piggy" when talking LandCruisers refers ONLY to the FJ55 model.
  7. DSRTRDR
    DSRTRDR I can mangle anything ... SILVER Star
    14,356
    Media:
    42
    Albums:
    1
    1,529
    Jan 4, 2005
    Baton Rouge, LA and Fountain Hills, AZ
    I don't agree
  8. 63beastly
    63beastly
    3
    Mar 1, 2007
    oops not a pig, here are some pics of the beastly beastie.
    :doh:My apologies, I dont how to change the original thread title, here are some pics. Just back from vehicle recovery due to dirty carb circuits. I love my wife, she carries a tow strap at all times.[​IMG][​IMG][​IMG] [​IMG]
  9. 63beastly
    63beastly
    3
    Mar 1, 2007
    Ahaa, I poked around a little, and I have 7.5* of Negative Caster, the PO put the al shim the wrong way, prolly assuming it was to correct pumpkin angle. I think once I remove it (shim) It will sit around 0, maybe 2* pos, perfect. Thanks for the tip, more tomorrow once I finish removing the shims and go for a test crash.
