this is a very inspiring thread. i'm about to turn to the dark side....![]()
Me too I am taking a three day weekend to get started
Hurrah pass ?
Search the FJ60 forum for a thread on that topic. IIRC it was godwin that did it w/ a Denso alternator.has anyone heard of anyone using the bracket where the smog pump mounts to, to attach a second smaller alternator to run accessories and a dual battery set-up?
this would be awsome as you could eliminate the smog pump and eleminate the need for adding an aftermarket pulley in that location...and add as many Hellas as you need!
Nice !Longs Canyon after Pucker Pass, Moab
I plan to do the welded up EGR to keep the PCV mod. Any concerns there?
Looping sounds like the best method.I don't have an idler pulley yet, would it be better to just leave the smog pump open, or cap it, or filter it? Can I run it closed loop if I put hoses between the two pipes?
Yep.The biggest confusion I had with the vacuum lines were the three hoses near the top of the carb. One goes to the choke opener, and the other 2 are plugged, right?
I wouldn't count on it. Leave the EGR valve & cooler in place until you definitely have a way to deal w/ removing it permanently. If there is no vacuum to the EGR valve, then the EGR system is dead. The big reason for removing EGR is cosmetics. It looks better without all that non-functional hardware hanging off the manifolds.Rubber expansion plugs work for both the EGR cooler and the pipe coming from the exhaust (short term)?
It is indeed, excellent.A clarification question on the EGR stuff. If I leave it all on the truck for the time being (I need to drive it tomorrow), I won't NEED to plug it, as the gases from the exhaust manifold through the cooler will not be an issue because the EGR valve needs vacuum to open. If that's the case, excellent!
26mmDoes anyone know what size chair/cane cap I need for the breather?
This is where I started to get lost.Why?
Wouldn't 15* base, plus 24* cent, plus 18* vac give 57* w/ all in?
Is 57* about 15-20 past optimum?![]()
On a side note, how important is the butterfly/heat riser in the exhaust manifold. Mine leaks thru the bushings and I was contemplating removing the assembly and welding the holes shut. I noticed the earlier manifolds do not have it. are they compatible with the later 2f motors?
Set it wherever it needs to be to not ping.I apologize if this has already been covered but I am unsure about what to set my timing at without a dizzy re-curve. My truck is experiencing the infamous pinging and I cant get it to stop. Not at idle only during acceleration.
Remove as much guts as possible. The vanes, the leaf springs and lip seals in the slots of the rotor.Does anyone foresee any problems with taking the vanes AND the fins out of the smog pump? Basically, I just need it to act as a pulley and the little cup spinning inside the smog pump seems like it'd be fine. Also, should I just cap the 2 hard lines coming out of the back of the smog pump?
I think that is ideally what you want, just a hunk of metal left with good bearings and cap the holes so as to not provide a spot for water to get in. Remove any parts that don't need to be there for the spinning of the shaft. Maybe drill a drain hole just in case water does get in.
