My 80 isn't accelerating correctly
Sherwood OR
my land cruiser isn't accelerating correctly when coming to a stop I have to shift it in to low first to get it to accelerate somewhat normally I replaced the egr valve but that wasn't it anyone know what is wrong and how to fix it?
Is it a tranny or motor issue, more details.
You shift it into low range first gear, or are you saying you manually shift into first gear? If you're in low range 4x4, you shouldn't shift back out into high range until you stop. If your truck doesn't automatically shift into first when you try to drive from a stop, I might disagree with a mechanic that says your transmission is sound. (I suppose it could be a vacuum leak that keeps it from shifting.)
What year is your LC? If you have the FE motor, and the truck is new to you, you may just need to adjust your expectations of how fast you'll accelerate.
If you put it into drive and it's 'slipping'. Then you shift into L and it engages 1st it's a transmission issue. Could be loss of electrical control. You need to read and follow the troubleshooting outlined In The FSM for your year.
I don't see what year your truck is.
If it is 94+, then you MAY have the "second gear start" button on the console. There are two buttons, one is labelled "PWR" for Power, the other is 2ND for Second Gear Start.
If the second gear start is engaged, it will feel very sluggish pulling off the line. That is designed for low range and driving in a manner to reduce the possibility of breaking traction.
Push the PWR button to cancel the 2ND button.
It is a 93
We can only help you based on info you provide. So far your details are slim - are you new to vehicle work or are we dealing with a language barrier?
Take your time, write up a detailed as you can possibly describe timeline of what went wrong, any new situations it started after or occurs at, etc.
So far we can't even guess if it's motor issues / not making the power or if it's transmission / not getting the power to the ground.
Otherwise the short sentences only mean we can point you at the manuals & say "here you go, good luck!".
As the saying goes - "help us help you".
And when you post up your detailed write up please for the love of god remember paragraph breaks every once in a while.
Nothing drives me away from real time help threads faster than seeing 2000 words lumped in a single paragraph.
nothing drivesmecrazierthanproperpunctuationandbrakesinsentencesandpropperspeling.makesureyoumakeitsowecanreadit.
thatwasreallyhardtotypewithoutspaces.
nothing
drive
smecrazie
rthanproper
punctuationa
ndbrakesinsen
tencesandpropp
erspeling.makesure
Their fixtit!
