- Joined
- Jul 12, 2005
- Threads
- 56
- Messages
- 371
- Thread starter
- #21
Cruiserbrettcruiserbrett said:I would find a 74 ish carb. you will need a clamp style airhorn(F engine only) carb inorder to use the 69 vintage manifold, since as you discovered it doesnt locate the carb properly for the 2F air cleaner.
you will need to find/make the return line for the carb if you go with the 74 carb.
Cool piggie. Looks clean!
What is a clampstyle air horn carb -- do you have a picture or reference? What kind of air cleaner do I hook up to her if I keep the 69 intake manifold? Do I plug the vacuum port on the 74 carb if I can find one as well as the vacuum advance port on the distributor?
Rhino mentioned JIM C to get a carb from --- does he have an alias?
Again -- thank you all for all the informtion -- this is great!!!!!
75Pig
