Build My 40 build
Member Build Threads
Well your FJ40 frustrations are gone for now.
JP
Jez-us. I just read this whole thread. I am fighting the urge to go slit my wrists. What a sad story. I am less than half way through my build and going broke and ruining my marriage. I feel like i just saw my sad future. Please lie to me and say some eager guy bought it and is going to care for it and drive it around on his farm where it can be free? That is where i tell my kids their dog has gone :cry::cry::cry:
If that’s true of your build then it’s time to pause your build. Marriage is more important than a piece of metal.
Nowadays it is probably a whole lot easier to find another quality wife than a quality 40!
How you do anything is how you do everything.
Here are some of the part Numbers I used, some could be discontinued by now.
LH RH​
Tail light brackets, 1972 75154-60012 75153-6001
Rear Reflectors, 1972 81910-69015
Radiator tube, 40 & 60 with A/C 16577-61120
Radiator tube W/O A/C 16577-61040
Foam, Hardtop side to hatch header 63167-90302
Clips Hardtop side to hatch header 63168-90302
Hardtop Weather strip 63168-90307
Top weatherstrip 65888-90302
Top weatherstrip 65889-90302
Hatch panel 3-69 to 7-72 67005-60012
Hatch panel 7-72 to 10-72 67005-90300
Hatch glass USES Updated weather strip 7-71 to 7-80 Rear 68131-90306
Wheels 15X5.5 with clips 42601-60072
Hubcap front 42621-60010
Hubcap rear 42621-60020
Mirror arms windshield mount 87902-60030
Mirror Support 72 style 87902-60050
Mirror Round 87901-60020
Mirror Square 87901-60011 87901-55011
Hatch lock 69540-60010
Oil Cap Push in 12181-31020
Gas Sender 72 & earlier 83320-35020
Door Main Weather strip 68109-60020 68108-60020
Door weatherstrip X2 68175-90300 68175-90300
Door weather strip X4 68213-90300
Door Inner Weather strip X2 68170-90300
Door outer weather strip X2 68161-60010
Front Rubber top 63161-60010
Windshield 56121-60011
Windshield 56122-60011
Hardtop corner glass weather-strip 62742-90300
Hatch weather strip 67871-90300
Rear Glass Uses updated weatherstrip 68131-90306
Glass top sides 62711-90300
Door lock 69510-60010
Door check, latch on tub 67451-60020
Wiper switch 84650-60050
Glove box packing 55549-60011
Glove box cable 55508-30028
Dash plugs 90950-01725 90950-01329
Dash Plugs 55321-90300
ROCKER plugs, 90950-01882
Dash plugs 90950-01154 90950-01156
Dash plugs 90950-01038 90950-01725
Oil tube 11452-61010 or 11452-60013
Dipstick 15301-60031
Turn signal assembly 72 older 84310-60022
Door handles outside. 69201-90901
Tank overflow (60) 16480-90A00
Tank overflow cap (FJ60) 16405-90A03
Overflow tank bracket (FJ60) 16611-61020
Cap and Hose (FJ60) 16405-60031
Temp sender (1972) 83420-20010
Shock washers 90948-03003 90948-03004
Turn signal switch 72 older 84310-60022
Washer nozzle 85035-60050
Radiator 16400-61020
Intake studs manifold to head step studs 90116-12324
Air cleaner wing nut 94271-00800
Allen head plugs Magnetic 90341-18021
Allen plug crush washers Steel 12157-10010 Aluminum 90430-A0003
Rear heater Motor Mods required 87104-87003
BOLT Wiper, light switches chrome 90984-01007
Fuel Tanks 69-72 77100-60012
Fuel Tank nut union 90402-13041
Fuel tank Olive 96395-71400
Heater control valve Later years 87240-60010
Hoses Radiator w/o ac 90916-01056
Hoses Radiator w/o ac 90916-01058
Hoses Radiator w/o ac 16571-60060
Hoses Radiator w/o ac 16261-60011
Steering column seal 72 older 55122-60021
Choke nut Dash 90179-14032
Hose clamps X3 90460-58013
Hose clamps X1 96111-10500
Hose clamp X2 96112-10330
Hose clamp X2 90460-49062
Hose clamp X121 for heater hose 96112-10250
Transfer Boot, 4 speed 36318-60010
Shift knob, 4 speed 33504-60030
Fuel strainer ???? 77200-60010
Hatch struts Aftermarket Gas JR products GSNI-5300-50
Alternator connector GM cs130 BWD PT200
AC Compressor Denso 4710204 or 4 Seasons 67384
Aftermarket 16X7” wheels, 12 series primer, 12-670604
