mushy brakes
Norcal, not on fire but it was darn close.
Do my father drove his 80 down a long hill really fast about 30 miles.
Hours later, on the way home the brakes would need to be pumped.
The pedal would go all the way to the bottom.
I had to be very cautious and drive very slow back home.
The next day they felt weird, lots of pumping.
I had them bled, and drove the 30 mile hill this time I drove slow and used the ECT and PWR buttons to take over drive off (Or what ever they do)
It felt ok but when I did an emergency stop test it felt like it was pulling pretty good to the right.
What do you think I need to get a master cylinder or something else?
All the brakes had been changed and rotors were good.
Most often that is caused from overheating old, contaminated fluid. The first step is to flush with new fluid and see if that resolves the problem.
Look at the color of the brake fluid in the reservoir. It should be a light clear yellow color. I bet it's pretty dark now. That would be your confirmation that @Tools R Us is correct.
...All the brakes had been changed......
Do you mean brake pads or the entire calipers? Changed before or after the original 30 mile downhill?
Bleed them again, twice. Adding dot 3 as you pump. Then while braking if it’s still pulling, acting weak, likely master cylinder. I paid $70 for reman mc after core refund. Very easy to change, not really cheap.
But you know brake are vital! Check for line leaks!
My seals were toast in the old one and pedal was to the floor for minimum brake effect.
