multi axe coupler on a M101
Montreal
Did any of you ever installed a multi axe coupler on a M101, if so, show me how you did it.
Tons of people using those Lock-n-roll hitches. The one in your picture is a weld-on one that is meant to be welded to the trailer tongue. There is another peice that goes on the truck to connect to that.
Here's the one I am using, showing both sides. Mine is a receiver style instead of a weld-on like you posted.
Trailer end on the tongue...
Do you have a picture on how you attached the tube to the m101 trailer?
My trailer is not an M101 or M416 but a homebuilt one. IIRC the M101 tongue has the two triangulated "arms" that are bolted/riveted to the pintle/lunette assembly at the end of the tongue. It seems like it would be as simple as unbolting/cutting out the rivets and removing the lunette ring, and then welding in a receiver tube between the triangulated arms.
Sorry I don't have pics but I'm sure others have solved this and can help more.
