Tires ,tires ,tires......most of the Swampers are your best bet , naturally.
If you don't already have it in your 80.......At least...a rear locker will make all the difference. That's about it.....other than a water hose/pressure washer.
Don't listen to the nay-sayers about how they hate mud , or 80's are to heavy. If you need to get through mud , they'll hold there own just fine.
After all , as an expedition type vehicle , mud holes are usually a given , at some point , in most locales , around the world.
If you aren't very experienced with mud , don't drive as you would in most trail riding/crawling situations.......Depending upon circumstances, most often , once you reach the deep goo ,
stay on the skinny pedal!!
Keep those tires spinning! Keep 'em cleaned out , until you hit hard ground. Your 80 will keep up with the best of 'em , if you
drive it.
Alot of people start pussy-footing at some point in a mud hole , and that's how they bog down in a heavy vehicle.
