Moving Hood at High Speed
Indiana
In an effort to avoid the Tommy Boy scenario I notice the corners of my hood move around quite a bit when I am scooting down the highway (65 top speed, in a tail wind, downhill). Has anyone experienced this? If so, is there a way of dealing with it or is it something not to worry about? The latch seems to be locking up right. I know the hood has been removed from the truck before and maybe that has to do something with it. Maybe I need to get a gasket replacement that goes all the way across the front of the hood. At this time I only have the gasket above the headlights.
Thanks for the help.
If it's the front corners of the hood that are raising up and down, you can raise the rubber bumpers on the corners a bit. (12mm wrench as I recall and a phillips screwdriver) If after the adjustment the hood sits slightly higher than the front fender corners, the latch assembly needs to be lowered and the rubber bumpers adjusted lower to align the hood back with the fenders. If the back of the hood is moving around, I would check the bolts on the hinges for tightness.
I had thought about that. I'll give it a shot. On occasion when I drop the hood it doesn't latch. Sounds like just some adjusting is in order. Thanks!
If the rubber bumpers at the corners aren't plump, they get flat over time, replace them. A relatively cheap and easy fix and they'll rebound enough to keep the hood snug while flexing enough to make it easier to latch.
While it is a great idea to have one, a gasket won't make much difference for this specific problem. There is a lot of air coming through the grill and radiator and that can lift the hood even if the gasket is in place.. as mine does the same and I do have all three gaskets.
There isn't a lot of adjustment in the latch.. or at least not in mine. And even with it all the way down, I had to lift the edges 1/2" above the fenders to get the hood to stop fluttering.
Others on the board have mentioned the problem is the lower layer of sheetmetal bracing under the hood skin has come unglued and this allows the hood to flex up on the edges. Seems plausible. I just haven't had time to properly clean the existing glued spots for regluing... (think I just made up a word)
Yes, I got into it to day and the member that the latch is on is pretty thin metal. I tightened up the screws and lubed everything. Almost like that member needs to be braced somehow. Thanks all for the thoughts.
Just to be more clear than I was initially.. I was referring to a lower piece of sheet metal on the hood itself. There is the upper skin that you see from the outside, then the formed cross bracing metal directly under the whole thing that is glued to the skin in a few spots. This is above the layer of insulation that is clipped to the underside of the hood. On mine the glue has come loose.. and people here have suggested that this can allow the hood to flex and lift the corners.
The latch can be lowered to tighten the hood up. I believe over time the hood starts to almost warp upwards on the front corners due to age and the bracing coming loose. To lower the latch you will need to elongate the center hole downward about 1/8 to 3/16". That should provide enough movement to tighten the corners up.
I'll be the 1st to say that I'm splitting hairs / being a fussy guy, whatever - but while this ::is:: a fix of sorts, it's going to accelerate the "dogears" the front corners are doing. I agree some hoods are getting warped like you say (fought it myself on the LX450)
What I did was in ways the same thing, but I thought on it as I had the center section under Rhino liner (real deal, 1/8" thick & heavy!) -- I finally decided to just jack/shim the passenger corner to push the center latch up & bsically lift the DS side marginally as it was a pivot point of sorts, and not stress the hood as bad.
I did shim the passenger side as I used the jacked up corner as my sightline down to where I place the RH side tires -yes, I fully know I was twisting the hood, but the bucktooth thing was so bad with the added weight I had a rub line in the grille where the rhino was touching & rubbbed out the chrome dip on the grille.
It was crooked to be sure, but the crooked beat going bucktooth, and the Rhino was so heavy it flexed the hood a little coming down if you were underhood.
The guys who Monstalined a whole hood or body may be facing this sooner or later - I had the Rhino in 2010 so I already had this issue. Monsta seems quite thinner, so IDK - I get Rhino for cheap yet so I've got no reason to look any further.
HTH the linered guys -- frankly I get the liner fun (heck I was a Rhino shop guy in the 90's -it was fun times!) -- but the weight of a liner like Rhino or Linex will warp a hood all on its' own.
/End of my fussy thing, Summit! :p
Thanks all. I considered it for my faded hood but opted for the wrap. I've checked at the bumpers are definitely touching on the underside of the hood. I will check the glue theory. Thanks.
I have the same issue above 50 mph. It is pretty scary and i've had a hood latch come undone at 65mph on the highway in a civic. When comparing my LC hood to that of the toyota pickup and civic, the bracing on my LC hood isn't connected to the sheet metal, I can separate the 2 with my hand by pushing on it. On the other hoods it is tack welded. Didn't know LC hoods were glued
After reading this thread,I went and adjusted mine. (same problem). Moved the latch down an 1/8" and the corners up an 1/8". seemed to help alot.
It is a known issue that the Ribs on underside separate from the hood. The hood is pretty much made of metal tissue paper.
Here is a ~$20 Fix
I drilled some holes with a step bit then used a can of High Density foam. Wear Nitrile gloves as this stuff is Nasty!
Let it setup over night then trim and protruding foam and put liner back up.
It's real solid now.
My only concern is if the Engine Heat may make it let go over time.
**Good Luck reusing the Hood Liner Clips as most broke. I bought a set off Ebay for $10 (GM I think)
Those white areas are where you used this stuff?
Yes, Trimmed it flush.
The Can has about a 6" Tube to you can direct it both ways using 1 hole.
http://www.loctiteproducts.com/tds/TITE_FOAM_tds.pdf
-40F - 194F long term exposure. I would guess that under hood temperatures are hotter than that but you could probably insulate it. We'll see how it holds up
With Air Gap and Fiberglass hood liner it may pass.
I have never shot the hood with a temp gun, but I know a dash will hit 140°F or more on a hot summer day.
If they got too hot the paint would likely show issues.
DANGER! EXTREMELY FLAMMABLE. VAPOR MAY CAUSE FLASH FIRE. VAPOR AND SPRAY MIST HARMFUL, OVEREXPOSURE MAY CAUSE LUNG DAMAGE. MAY CAUSE ALLERGIC RESPIRATORY AND SKIN REACTION. CONTENTS UNDER PRESSURE. This is ok to use under the hood?
Regluing the stock spots with urethane is probably sufficient.
Edit: or even better, they make glue specifically for bonding body panels.
Cured combustion at 240F. Might be better to tack weld with little nuggets of jb weld?
