motor mount question - real time
Tacoma, WA
on the rear motor mounts, do the concave ends of the motor mounts face each other (which is what Im thinking), convex ends face each other, or should the convex/concave ends both face up or down...
thanks in advance. my old ones are so mangled (and I think one may have been installed wrong)
mike
edit, question is for the passenger side if that makes a difference
Passenger side: concave face each other.
:cheers:
I just did this today. My question is the hardware involved. I have the large bolt and nut. Seems to me that there needs to be some type of washer(s) with the castle nut and cotter pin.
Factory hardware was castle nut and cotter pin....
I like fine thread grade 8 bolts and metal locking nuts. ;)
(but that is just me)
:beer:
The original bolts get eaten up pretty bad over time. The replacements at SOR, for example, are only approx $7, but the time and shipping make it not worth it unless you are ordering other things.
:beer:
was there any space between the hole for the cotter pin and the castle nut. I.E. , maybe too much play. Or does one not cinch down too tight?
If the donuts are now hucky pucks, you will have excess space. I just changed mine, and they were sloppy loose before. They are now snug.
The mounts should not be tight (torqued down) anyway. You should be able to move them side to side with your hand without much effort.
Fair enough question. First off, you DO realize that are two different length bolts, left and right? If you have extra threads, you may have the longer bolt in the shorter hole.
In any event, every so often I will have a customer come in with cushions that are still reasonably tapered [not flat] that have threads showing. My prescription is to stack washers inbetween the donut and the castle nut with the castle nut snugged at the outer cotter pin hole. That way, as the donut continues to compress, you can follow the castle nut down to the second hole without having to scrounge up more washers. If it takes more than 4 washers, you prolly need a new donut anyways.
I like doing it this way because you invariably find out that the mounts are loose when you're on the trail.:eek:
Best
Mark A.
Strongly disagree.
A thousand pounds of drive train being able to shift freely on its moorings does nothing to increase the life expectancy of the front mounts, nor the rear brackets and other pieces in the system.....one would think....
What is the proper installation for the driver's side rear motor mounts? They were just stacked one on top of the other before so that's how I put it back but was wondering if it's right.
