More Volvo Axles
Reno, Nevada
Thought I would show some pictures of my 80. It is a 94 and I have owned it for about a year. Now for the important stuff. It has Volvo axles, link suspension, coilover front, OME rear w/ bilstin, 37" Krawlers w/ duel beadlocks. We built the front bumper and a winch will follow and are curently working on the rear bumper as well as installing the rock sliders. Over the winter I hope to install the external cage w/ built in roof rack.
Nervous about that front link being so low? I hope it is beefy as it will be a rock finder for sure!
All lower links are 2" x 3/8" wall, not likely to bend. It is also about 18" off the ground at the axle. Pictures don't show things well, there is a fair amount of clearance.
I personally think that this is the solution for people who want to run the big meats on an 80. The portals allow what are near stock suspension geometry linkage because the axles are creating the big lift, not the coils with resulting highly angled links.
Any time you can raise the axle end you are gaining wholesale improvements across the board in clearance and geometry. Very, very nice. The 8" lift on the 2" suspension, love it :cheers:
Oh wow. Another one! Sweet! I look forward to seeing some action pics and video.
What link do you speak of? I see nothing even close to being a rock catcher.
That Y link front looks like it is low in the pic, because you don't see the actual straight arm link with upper arm mount from a proper angle.
Tell you what; I'm interested in that rear axle upper reverse link.... Very interesting way to set axle angle, Have any binding issues with that set up?
-Matt
No binding at all, yet. We haven't flexed it out yet but hopefully withing the next few weeks. I have checked the droop and with a 5' tall high lift, I top out the jack before a tire lifts. That is from the edge or center of frame.
Really impressive rig! Nce work and attention to detail. Its almost as thought you had someone in your corner who had been down this road...... ;)
Very nice ...........:flipoff2:jerk................ Just kidding.
You have done a dreamy job on that one, cant wait to see a little Vid of that crusher in action.
How are the brakes on those things ? Drums all around correct ?
Does the 80 brake master work (volume wise) with the Volvo cylinders or is it not really an issue if you keep them well adjusted.
I know the axles give you 5"...how much extra lift with that suspension?
