More Flex
Just after some imformation on how to get more flex/articulation out of an 80. I have a 2 inch lift. thinking of going to 4 inch. What eles can i do ???
I thought about my suspension a lot when I wanted more flex. No matter how much I kept thinking, it still flexed the same...it was terrible.
Then one day, I installed the suspension I was thinking about, and it actually flexed better!
:flipoff2:
Flex is a tough subject to talk about in the abstract. Suspension travel is hard to measure in reality. I learned on Desert racing buggy systems that reached 36" of wheel travel. That is 3 feet! A car with 36" of wheel travel had only a 30" suspension area in which to exert real traction, placing the weight of the car on the ground..
Very few LC's can reach that far up or down.
What matters most is that the wheel that is lowest, or has the least traction will keep its grip. You need to nurture that wheel. Or if so equiped, you just turn the lockers on and drive away.
I have seen the outback offroad long armkit and it is VERY flexy, but also a bit spendy for the extra 12-16 inches you get on the RTI ramp. I have the Slee 6" kit with 37s and I can go anywhere I want with lockers, no real issues with flex since I can wheel stand if I need to, just have to be careful about COG if you are in the steep stuff.
Here is a little tid bit that I haven't seen discussed here at all
X-link
The 80 does well with some rigidity in the front end - it keeps it stable and balanced. With two lockers, you really want to focus on maximizing tire size and forget about trying to make the 80 super flexy.
My rig feels about as flexy as my old Jeep XJ, even though it isn't in raw terms. I had thought I would want to mess with the front end, but now I view it as a smart design balance. Big tires, low gears, lockers...that's the formula for an 80.
Sway bars on an 80 do not limit your travel. Flex/articulation is the same.
on a ramp yes but not in the real world
if you place enough load on the front end it will flex but it takes a lot of loading to get it there. I want the front end to flop around without fighting. I want the front as floppy as the rear. removing the front sway bar makes a considerable diff on this truck in real world wheeling
for instance if you lift the drivers side rear tire about a foot and then lift the pass front tire you can show some good flex in the front end. but if dont lift the drivers rear tire and lift the pass front there is much less flex. the sway bar contributes to this situation.
x2 I've wheeled mine with every sway bar combo you can. No sway bars ever again for me...
Show me a rig that competes off-roading in an organized level that is using sway bars while racing/competing.....?
I'll gaurantee you that he is an amateur.
:beer:
Lots of debate about sways. I've run both ways on all three Cruisers. I like the ride without them as the axles move more freely. Dangerous on the road.
Technically speaking....travel is travel and the 80-series "flex" does not increase without the bars. Doe they articulate easier? Yes.
I think the thread postee (CPTMUD) was speaking of increasing travel....which removing sways does not do. :)
:beer:
That doesn't matter - the 80's front end is rigid enough that the swaybar is very little of a limitation. It's not like a Jeep where your travel explodes when you disco the swaybar.
I take the front off and leave the rear hooked up and find it to be very balanced. The 80 is a pretty unique rig for crawling...the standards you might apply to a typical vehicle don't work well here, because of the size and weight. You don't want to take a full body 80 and unhinge it with the expectation of gaining performance on the trail.
In fact, if I was going to go big and wanted to make a change, I'd be looking really hard at a rear leaf conversion with a front 3 link, so you have at least one end keeping stability without messing with a ton of high angle links and swaybars and crap, while still having good flex. You could easily get 6" of lift on an 80 with a flat leaf spring in a spring over design with good flex (much better than the 80's front flexes) with good stability and then unleash the front a bit. I think this would be about the most interesting 80 series suspension project out there.
I know this will get a bunch of "leafs springs on an 80???" responses as if this is some sort of ghetto idea, but the rear leaf/front coil suspension design is very well proven and IMO addresses much of the difficulty of modifying an 80 for hardcore multipurpose use (rock crawling, expedition/family trips, mall crawling). The weight bearing design of a good leaf spring for the extra rear weight most carry while increasing overall suspension flex front to rear without sacrificing the balance of the suspension is a worthy goal, and with good leafs that's all you need - no swaybar, no extra links except a traction bar to eliminate spring wrap, and you get mounts up to axle tube height to eliminate rock catchers.
Just looking at all of the endless posts trying to balance front and rear spring rate and load bearing is an indication of the difficulty of getting a quad coil suspension to handle our dual use without unfavorable dynamics either loaded or unloaded.
So to me, the question isn't "More Flex?". It's "More Balance?", to which "more flex" is only partly an answer if properly designed. Fortunately I have neither the time nor money to pursue this, so I'll just have to keep wheeling my unflexy rig without all that much lift but with outstanding balance and the ability to run big tires :grinpimp:
Nay
Now that this thread is starting to run off on a tangent...
What is your goal? Fill us in and we can better point you where you want to go.
