Moog U joints
Are these good? I see they have the grease fitting so I was planning on getting them but I figured I should ask here first
By the time I get done with a rebuild (ujoints, balancing, etc) the cost of new driveshafts was worth it to me relative to time. I haven't ever rebuilt a GX driveshaft in 10 years. I always end up swapping. I have done front and rear twice in 10 years with heavy offroad use.
Moog has gone downhill in the recent years, IMHO. I used to insist on their parts but have had bad luck with them (not on GX). I would look at Spicer options instead
I found that my local driveshaft shop is so cheap (and can always get the correct Spicer joints) that I just take the shaft to them for such work. This shop insists on non-greaseable Spicers (for my Ford) because greaseable ones are weaker. I decided not to argue the point about serviceability, but I prefer greaseable.
I rebuilt one on my 99 Tacoma about 12 years on the tailgate with a shop hammer and framing hammer. I used a non greaseable that was on hand at the parts house and it's still in there 70k miles or more later. But, I was in a bind and needed it and I still can't believe it's lasted this long.
If you have a NAPA locally see what they have for their uppity store brand. It's usually something by the manufacturer that whatever OEM uses.
Thanks for the info everyone. I’m swapping my LCAs tomorrow and hopefully that gets rid of my vibration/shaking. Next will be ujoints or maybe just new driveshafts now. I’ll have to see how close the costs are
I used greasable SKF joints from NAPA. Marked everything before disassembly. Used a big vise and some sockets. Moly greased the spline fittings and lock tight on the flange bolts. Smooth as silk now.
